VX/y8 head mini me swap.
Old Feb 11, 2003 | 06:12 PM
VXpride's Avatar
Default VX/y8 head mini me swap.
ok. I have a VX block and I'm getting a y8 head for it. I already have a z6 Intake Manifold on there. Right now I'm trying to make a parts list, and I know I need a head gasket, what else do i need to add to my list?? and What would you guys recommend for a milling too? Thanks
Old Feb 11, 2003 | 06:39 PM
slammed_93_hatch's Avatar
Default Re: VX/y8 head mini me swap. (VXpride)
ecu
Old Feb 11, 2003 | 06:50 PM
Patrick's Avatar
Default Re: VX/y8 head mini me swap. (slammed_93_hatch)
ecu
Thats all ya need, really. I did this myself, but with a z6 head. Do a search and you will find a ton of info.
Old Feb 11, 2003 | 07:22 PM
function83's Avatar
Default Re: VX/y8 head mini me swap. (gsr_vx_hatch)
z6 timing belt.
and a new headgasket of course.
VXpride's Avatar
which timing belt do I need z6 or y8? and is it ok if i have the vx ecu in there for a while, or is it absolutely necessary that i get a p28? Any suggestions on the milling?
Old Feb 20, 2003 | 07:32 AM
osf's Avatar
osf
I've think you need a ecu for a y8 I am putting a p&p y8 head w/jgcam on my Y5 block (hx) and I have a head, ecu, intake manifold, and of course gasket kit should be in next week I'll let you know if anything else comes up
Old Feb 20, 2003 | 08:27 AM
heel_touge's Avatar
Default Re: VX/y8 head mini me swap. (osf)
the y8 intake mani is the best you can get, so if it comes with the head your in luck.
vtec-e is completely different than vtec. so the ecu wont work.
Old Feb 23, 2003 | 08:02 AM
Turbo'dMex-A-Keen's Avatar
Default Re: VX/y8 head mini me swap. (1slowcivic)
Yes u are right I just found an EX in a junkyard complete it has never been touched and i went to pop the hood, when i looked i almost splooged cause it had the y8 manifold, y8 head, and EX tranny, im getting all except the tranny for 150. Even the ecu and wiring harness.
Old Feb 23, 2003 | 08:04 AM
Default Re: VX/y8 head mini me swap. (djhatch)
z6 timing belt.
No dude not a z6 a VX its what all mini me swaps are done with.
Hondalover15
Dec 5, 2012 10:13 AM
Commiecircusbear
Feb 12, 2008 01:21 PM
keepinitsimple
Feb 17, 2005 11:32 AM
FLATBLACKEG
Apr 5, 2004 09:29 PM
sleepyhamsterlx
Jan 5, 2004 08:21 PM
