coil over help
Old Feb 10, 2003 | 08:57 PM
chinaski's Avatar
Default coil over help
i dont know how to install them cuz i didnt get any instructions with mine. i have searched the forum and found nothing about installing only if one brand is better than the other.
Old Feb 10, 2003 | 10:34 PM
TimoneX's Avatar
New User
Default Re: coil over help (Shu92)
Well who manufactured your coilovers? Which dampers are you trying to use them with? If they're sleeves then the instructions vary depending on the dampers you're installing them with. Try contacting the manufacturer or taking them to a suspension shop.
Old Feb 10, 2003 | 10:39 PM
Type Wah's Avatar
Default Re: coil over help (TimoneX)
quesion: I just received my coilovers in the mail, it came with all the parts to install.. I was wondering if I need aftermarket shocks to do a 1-2" drop, or can i use my existing stock shocks/struts?
will my ride change dramatically? or just a lil rougher?
Old Feb 10, 2003 | 10:51 PM
TimoneX's Avatar
New User
Default Re: coil over help (Type Wah)
You can almost certainly use the stock dampers, though they'll likely not last too long with a 2" drop. As far as your ride, that will depend on the specific spring rates of your springs, and the ability of your dampers to well...damp your springs at whatever ride height you end up with.
12345678910jdm
15
Jul 29, 2011 12:53 PM
2GEN DA
Honda Civic (2001 - 2005)
13
Jul 31, 2006 10:48 PM
97LXAcc0rd
Aug 19, 2005 12:21 PM
Mr.SpiLLz
May 12, 2003 10:20 PM
oryanh
Feb 8, 2003 08:10 PM
