tranny rebuild ?
Old Feb 10, 2003 | 07:16 PM
black-hatch's Avatar
Default tranny rebuild ?
how hard is it to rebuild a honda tranny i mean ive done engine rebuilds and stuff just wondering if i would be capable of doing one any input would be great thx.
Old Feb 10, 2003 | 08:04 PM
wignersfriend's Avatar
New User
Default not bad
I think it's just as easy. There are more times that you'll need to use a hydrolic press, so that would be a major consideration. W/o one, I think all you can effectively do is the 1st gear synchros, shift forks and some bearings in the case. No problem if you have a Helms. It's the only one I know of that explains the slightly different size teeth on the 5th gear. I tried mine w/ a Chilton's and that led to repeated removal/disassemblies before a mechanic friend showed me.
Old Feb 10, 2003 | 08:48 PM
sleeper4dr's Avatar
Default Re: not bad (wignersfriend)
all you really need to rebuild a b-series trans is a bench vice (for removing the nut on the mainshaft), a decent set of tools, and a good work area.
i've rebuilt my GSR YS1 trans and i attempted to rebuild my JDM S1 trans and neither required a hydraulic press. the helms manual says you need a press but i've never needed/used one.
and i think you meant the 5th gear synchro (on the counter shaft). the 1st gear synchro is at the bottom of the gearset.
Old Feb 12, 2003 | 07:50 PM
New User
Default cool
so how did you do it w/o using a press?
why do you say that you've only attempted a jdm s1? I have a jdm S1 and would like to know if there's a particular difficulty in those.
what I actually did was use a copy of someones b-series helms instructions as a guide to an L-series tranny for my old d16, which was grinding into 2nd. That was the only synchro that was accessible.
Old Feb 12, 2003 | 09:24 PM
sleeper4dr's Avatar
Default Re: cool (wignersfriend)
the gears were not that hard to just pull off of their respective shafts. i just re-installed the gears without pressing them and they are working fine.
i say i attempted to rebuild a JDM S1 trans because i was trying to replace my 3rd and 4th gears with 92-93 GSR gears and it did not work out.
as for the gear thing. 5th is on top. its the easiest gear (on the counter shaft) to get to no matter how you look at it. thats why i thought you maybe meant the 5th gear. here's a pic i just made for everyone. courtesy of helms and myself
Old Feb 13, 2003 | 06:41 AM
Jeff C's Avatar
Yes, you can so it without a press, but may I sugest this...Lock Ring Pliers
Sears # 47386.
Old Feb 13, 2003 | 08:33 PM
Default Re: cool (Jeff C)
thanks alot man all that stuff does kinda look a little intimadating thow
Smurf accord
Jan 27, 2014 11:03 PM
dm23
Apr 13, 2008 06:53 PM
JDM Like Whoa
Dec 11, 2006 10:11 PM
Tire Monkey
Jan 29, 2004 12:19 AM
thexiong
Apr 8, 2003 09:57 AM
