ls/vtec
Old Feb 10, 2003 | 02:50 PM
NismoNX's Avatar
Default ls/vtec
I need to know what to do with the wire for the det. sensor on a ls/vtec. Also the car randomly revs from 1k to about 2.5k by itself alot. Any ideas people.
Old Feb 11, 2003 | 07:54 AM
NismoNX's Avatar
Default Re: ls/vtec (NismoNX)
Come on dammit some of you have to know what to do with this ****. I mean damn it is a honda, and this IS honda-tech.
[Modified by NismoNX, 9:54 AM 2/11/2003]
Old Feb 11, 2003 | 03:07 PM
Jeff C's Avatar
Refresh my memory...what is a det. sensor?
The irratic revs could be attributed to the Idle Air Control Valve...it is located on the back of the manifold. Do you have access to another one that you could put on and see if that is your problem?
BTW, a simple "ttt" or "bump" would have worked.
Old Feb 11, 2003 | 03:36 PM
NismoNX's Avatar
Default Re: ls/vtec (Jeff C)
Thanks for the response. I mean detonation sensor, or knock sensor. WE have an extra IACV that we are going to try, I thought someone might know of something else it might be. I noticed you live in TN. Where is Dandrige?
[Modified by NismoNX, 5:38 PM 2/11/2003]
Old Feb 13, 2003 | 05:36 AM
NismoNX's Avatar
Ok does anyone know what to do with the wire for the knock sensor. The car is a 94 coupe ex and we have put in an ls block with a b16 head. The ecu has the wire for the knock sensor and the block doesn't have one. We have been told that the Vtec won't work until the knock sensor wire is right so please if any of you know what we can do please let me know. We don't want to drill and tap the block to put in the knock sensor.
[Modified by NismoNX, 7:36 AM 2/13/2003]
Old Feb 13, 2003 | 05:54 AM
Jeff C's Avatar
C-SpeedRacing
About 3/4 down the 1st page (3rd pic from bottom) they show where they mounted their knock sensor.
Old Feb 13, 2003 | 05:20 PM
NismoNX's Avatar
Thanks man, that really helped alot. Especially since noone else wants to help me.
rusureboutdat
Jul 28, 2004 10:42 PM
LSVTEC96HB
Oct 7, 2002 06:18 PM
