What would be the benefits of this?
Old Feb 10, 2003 | 07:43 AM
The G2 Racer's Avatar
Default What would be the benefits of this?
Running these parts from an ITR in an Eg suspenison ITR front lower control arms, and damper forks, ITR rear lower control arms, ITR shocks all around what would the benefits be? Do you have to run ITR springs to or no?
Old Feb 10, 2003 | 10:19 AM
Default Re: What would be the benefits of this? (The G2 Racer)
bump
Old Feb 10, 2003 | 10:23 AM
neof69's Avatar
The front LCA's will allow you to install an OEM front swaybar. As for the shocks they are stiffer than OEM civic shocks but thats about it..and i think "R" LCA's are lighter than civic LCA's (REAR)..
Old Feb 10, 2003 | 12:12 PM
kommon_sense's Avatar
Default Re: What would be the benefits of this? (neof69)
rear ITR lcas are also beefier and won't flex as much as regular civ/teg lcas. only problem is that you have to use itr rear shocks as well because they mount differently.
Old Feb 10, 2003 | 12:31 PM
euclid's Avatar
Default Re: What would be the benefits of this? (kommon_sense)
i think you can use any spring from any eg/ek/dc2 car... the only difference would be the spring rates, which would be softer to firmer ,respectively.
OoAoO
May 31, 2008 08:17 PM
8o8da9speed
Nov 18, 2004 05:20 AM
nikolai.
Nov 10, 2003 03:54 PM
fuguman
Aug 27, 2002 02:04 PM
ESCALVANTE
Dec 8, 2001 08:18 PM
