What would be the benefits of this?
1 Post
Running these parts from an ITR in an Eg suspenison ITR front lower control arms, and damper forks, ITR rear lower control arms, ITR shocks all around what would the benefits be? Do you have to run ITR springs to or no?
Re: What would be the benefits of this? (The G2 Racer)
The front LCA's will allow you to install an OEM front swaybar. As for the shocks they are stiffer than OEM civic shocks but thats about it..and i think "R" LCA's are lighter than civic LCA's (REAR)..
Re: What would be the benefits of this? (neof69)
rear ITR lcas are also beefier and won't flex as much as regular civ/teg lcas. only problem is that you have to use itr rear shocks as well because they mount differently.
Re: What would be the benefits of this? (kommon_sense)
i think you can use any spring from any eg/ek/dc2 car... the only difference would be the spring rates, which would be softer to firmer ,respectively.
ESCALVANTE
12-08-2001 08:18 PM
