What's needed to install ITR LCAs on an EG? and other ?s...
When installing Rear ITR LCAs on a '92 VX, what's need other than the LCAs? Is it a direct bolt on? Is it the same with the ITR springs or do I have to have the stock rubber spacer or something or other?
TIA
TIA
Re: What's needed to install ITR LCAs on an EG? and other ?s... (ESCALVANTE)
Well if you are gonna do ITR springs an shocks then you need ITR LCA's. Why do you want to put them on?
direct bolt on, all you need are ITR REAR SHOCKS to slap rear ITR LCA's on an EG.
you do NOT need the ITR springs
Re: What's needed to install ITR LCAs on an EG? and other ?s... (mr. skelly)
I have the ITR shocks, springs, and rear (no fronts) Lower Control Arms sitting in my garage waiting to go on my EG and i just wanted to make sure those parts could go in without having to install other parts.
I wanted to install this because I have heard good things about the stock ITR spring/shock combo from amateur autocrossers, circuit heads, and canyon carvers.
One person pointed out that the ITR shocks were better than the Tokico Blues. So for $180, the ITR spring/shock combo is a good "bang for your buck" mod.
if swapped ITR LCA, springs and struts into EG, then will ITR front and rear sway bars bolt right in?
If anyone has done this swap into a EG, how much did it lower car from stock height?
thanks
thanks
skribblah
07-26-2003 11:14 AM
AThiker
02-26-2003 10:12 AM
The G2 Racer
02-10-2003 12:31 PM
