rotating the crankshaft
Old Feb 9, 2003 | 09:51 PM
_Endless_'s Avatar
Default rotating the crankshaft
some people use a socket and rachet to rotate the crankshaft when making valve adjustments and you have to turn counterclockwise for a honda engine. if you rotate the crankshaft counterclockwise, is there a limit on how much you could rotate it? coz when i tried rotating mine, it lets me rotate only about close to 1 turn and it won't move anymore, i didn't try harder anymore coz i'm afraid i might break something. is that normal? or should the crankshaft keep on rotating as long as your turningt the bolt?
i did mine while the front is on jack stands and tranny in neutral.
Old Feb 9, 2003 | 10:00 PM
Kamin's Avatar
Default Re: rotating the crankshaft (_Endless_)
keep going.
it gets harder/easier at certan points.
remember you are moving 4 pistons and a heavy crank. not to mention cams and valves connected to springs.
Old Feb 9, 2003 | 10:54 PM
Nameless RB26's Avatar
Default Re: rotating the crankshaft (Kamin)
take the plugs out and it's easier..
Old Feb 9, 2003 | 11:02 PM
leadfoot78's Avatar
I rebember when I first got my swap i tried to turn it with the plugs in the I almost tipped the motor over on my foot.
Old Feb 9, 2003 | 11:17 PM
Default Re: rotating the crankshaft (leadfoot78)
<---done it. But with a V8. Luckily it only pinched my toe..
Old Feb 9, 2003 | 11:32 PM
_Endless_'s Avatar
so you guys are saying that it should turn all the way no matter how many?
coz when i first turn it counterclockwise, it turned very easily without having to exert much force. then after about 1 turn, it just won't move anymore, not one bit like something is blocking it. i then turn it clockwise to the original position, again it turned easily but about 1 turn clockwise, it gets stuck again.
by the way, i'm turning with only 3 cylinders coz i blew the #4 coz of detonation.
Old Feb 9, 2003 | 11:47 PM
If you're turning it on the compression stroke with the plugs in it, then it will be hard to turn. If you try hard enough, it will spin both ways..
You blew number 4? Is there internal damage do you know? Maybe there's something blocking it..
Old Feb 10, 2003 | 01:11 AM
_Endless_'s Avatar
Default Re: rotating the crankshaft (Nameless)
cylinders 1-3 seems ok from underneath(oil pan removed) but #4 piston/rods was shattered. i took all the bits and pieces out before turning it, i didn't take off the plugs maybe that explains why it's hard to turn at some point. anyway, thanks guys.
Old Feb 10, 2003 | 05:39 AM
Civic's Avatar
that would explain the force needed. sorry bout that
freshvibes
11
Jan 24, 2008 09:30 PM
gangstacritta
Jul 18, 2007 02:55 PM
kapitalc
Apr 21, 2007 06:39 PM
94B18B1Teg
Nov 30, 2003 03:20 PM
See Are X
Nov 9, 2003 09:09 PM
