sparks?????
Old Feb 8, 2003 | 09:23 PM
gumbybum's Avatar
Default sparks?????
WTF? i just tried to re-connect my battery and there were mad fukin sparks that arced the terminal to the wire..i have never had this happen to me WTF is going on? please help me and also my car still wont start? i hate this, it is ridiculous the problems that i am running into. PLEASE HELP ME......
Old Feb 8, 2003 | 09:54 PM
gumbybum's Avatar
Default Re: sparks????? (gumbybum)
anyone?????please.....
Old Feb 8, 2003 | 09:59 PM
97hb's Avatar
Did you put the positive side on first, then the negative??? You might have blown a fuse or two.
Old Feb 8, 2003 | 10:05 PM
gumbybum's Avatar
Default Re: sparks????? (97hb)
what fuses would be blown? i checked them..none. i dont understand why this is happening, too may problems
Old Feb 8, 2003 | 10:12 PM
Volcom's Avatar
You'll get some sparks when connecting the battery. It's normal, just put the cable on and get it tight.
Old Feb 8, 2003 | 10:15 PM
gumbybum's Avatar
Default Re: sparks????? (Volcom)
no there was mad sparkage and it melted the terminato the cable????
Old Feb 8, 2003 | 10:27 PM
Volcom's Avatar
Ok that's too many sparks. are you crossing the positive and negative terminals? Just trying to figure out why you're getting that many and that hot of a spark. I've seen a guy accidently place a wrench across the two terminals.
Old Feb 8, 2003 | 10:34 PM
gumbybum's Avatar
ya im tryin to figure out hy im gettin that many too?? i think im hookin it up correctly? im kinda dislexic so iono. + then - or - then + ive tried them both WTF?
Old Feb 8, 2003 | 10:35 PM
XDEep's Avatar
if it melted then you got a short somewhere.. thats what fuses are for
Old Feb 8, 2003 | 10:52 PM
gumbybum's Avatar
Default Re: sparks????? (XDEep)
the fuses are all ok. where else could there be a short? all of the cables and wires look ok. im gettin so frustrated... but you guys are helping a lot, thanx
Old Feb 8, 2003 | 11:25 PM
97hb's Avatar
Only wires that are not fuse is the starter and the abs. All the rest are fused through the box next to the battery. Also any ghetto wiring you may have done should be checked. Sounds like a positive wire that is not fused or fused larger than the capacity of the wire is the problem. Look at the wire that is melting, I bet the problem is there.
quetzalcoatl
Oct 1, 2009 02:55 PM
logeywartooth
Feb 4, 2009 06:23 PM
combos
Sep 16, 2008 08:56 AM
elrandeeto
Aug 8, 2005 11:37 AM
VTi NA
Nov 14, 2001 04:54 PM
