Increasing the redline and rev ability on a b20?
Old Feb 8, 2003 | 10:43 AM
FDragger's Avatar
Default Increasing the redline and rev ability on a b20?
so the b20 has a low redline, like 6800 or something like that. lets just say someone wanted to make it rev higher like 8000 and be reliable. what steps should you take? and is it even worth doing?
did a search but found nothing
Old Feb 8, 2003 | 10:54 AM
TimoneX's Avatar
New User
Default Re: Increasing the redline and rev ability on a b20? (FDragger)
Well you could put in a B18c crank & rods, put in a b17a crank & custom rods, put on a crank girdle &/or go with the longer Eagle rod/raised pin piston combo. Make sure your valve train can handle it, and make sure it actually makes power up there or this is all pointless.
Old Feb 8, 2003 | 12:39 PM
tegasaurus's Avatar
upgrade the valvetrain, skunk stage 2 with supporting stage valve/springs. A lighter flywheel will put less stress on the crank, so that will help. shave/balance the crank. Lighter internals, like some eagle rods and je pistons. should do it.
Also, the sleeves on a b20 are rather week. From what i hear they tend to crack near the top and split downward. A block gaurd will help, but for the full protection, get it resleaved with some darton sleeves or GE.
-Ryan
Old Feb 8, 2003 | 05:59 PM
Blaze45's Avatar
Brrraaaap!
Default Re: Increasing the redline and rev ability on a b20? (tegasaurus)
I know a guy on superhonda that revs his b20 to 8k and shifts @ that rpm and he ran a 14.3 in a CRX> his name is AK CRX. As for the r/s ratio its 1.53 and 7mm sleevs... you ll have to tune really well to prevent detonation, good luck
Blaze
Old Feb 8, 2003 | 06:06 PM
EuRoBrO's Avatar
Default Re: Increasing the redline and rev ability on a b20? (Blaze45)
Thats pretty slow for a B20 in a crx, there is a guy by me runnin low 13's.
Old Feb 8, 2003 | 06:09 PM
Blaze45's Avatar
Brrraaaap!
Default Re: Increasing the redline and rev ability on a b20? (EuRoBrO)
What are the mods and what is your sea level>
Blaze
Old Feb 8, 2003 | 06:57 PM
DirtySock's Avatar
Rev-ablity is all about rod to stroke ratios. Read up on them and youll understand why.
Old Feb 13, 2003 | 07:36 AM
DevinW's Avatar
It is worth doing, if you take the time and money to do it right. New, lighter, balanced internals (pistons, rods, valvetrain, block girdle) will allow for the redline to be a little higher...you'll need cams to make power up there though. Crower makes nice cams for the non-vtec b20.
cloviskilla
12
Aug 15, 2010 01:42 PM
wreckedmyteg
Apr 15, 2004 04:09 PM
FreeMyndz v.FP
Jan 14, 2002 04:05 AM
ezark
Nov 6, 2001 12:23 AM
XSBoost
Jun 12, 2001 10:46 AM
