Stripping IM Bolt: Pic: How To?
Old Feb 7, 2003 | 09:18 AM
mr_mbuna's Avatar
Default Stripping IM Bolt: Pic: How To?
Hey guys, I'm taking the intake manifold off my B18B1 engine, and I've gotten every bolt off except this one final one. It will not budge. I've tried using the PB Blaster spray too, with no success. I'm beginning to strip the head, which is going to be very very bad.
How do I get this bitch off?
Ben
Old Feb 7, 2003 | 09:40 AM
Sleeper's Avatar
Default Re: Stripping IM Bolt: Pic: How To? (mr_mbuna)
Are you using a 6pt or 12pt socket? If its 12pt get a 6pt and try it. If you already rounded it, use vice grips and you'll need a new nut.
Old Feb 7, 2003 | 09:43 AM
SuperSH's Avatar
Default Re: Stripping IM Bolt: Pic: How To? (Sleeper)
IF that dosen't woirk try heating it a little bit. Heat will cause the nut to expand and release from the stud.
Old Feb 7, 2003 | 10:05 AM
brcivic411's Avatar
Default Re: Stripping IM Bolt: Pic: How To? (SuperSH)
as a last resort, just get a bolt/nut breaker and buy a new one.
Old Feb 7, 2003 | 10:18 AM
mr_mbuna's Avatar
Default Re: Stripping IM Bolt: Pic: How To? (brcivic411)
I've used socket wrench, vice grips, adjustable size wrench (not sure of name), I'm piling up the tools here. There just isn't enough clearance around it for most tools to move. I don't care if I break it as long as I don't break the IM or engine or have to get it drilled out.
Ben
Old Feb 7, 2003 | 10:54 AM
Tweakmeister's Avatar
yeah try heating it with a torch
use a 6pt with a breaker bar...you'll get it out.
Old Feb 7, 2003 | 11:12 AM
Kamin's Avatar
Default Re: Stripping IM Bolt: Pic: How To? (Tweakmeister)
vice grips then hit it with a rubber mallet. it will work.
Old Feb 7, 2003 | 03:15 PM
bigTom's Avatar
use a long 12 point wrench
Old Feb 7, 2003 | 03:21 PM
splitime's Avatar
Default Re: Stripping IM Bolt: Pic: How To? (ek9t)
12pt is bad, it'll strip it more. 6pt has better surface, thats why they suggested it earlier.....
Old Feb 8, 2003 | 01:41 PM
Default Re: Stripping IM Bolt: Pic: How To? (splitime)
update:
he needed an open end wrench (which he didn't have at the time).
problem solved.
Old Feb 8, 2003 | 09:03 PM
smokey2.0's Avatar
I will support the 6pt rule. i stripped my belt tensioner bolt using a 12pt socket, and some one told me to use a 6pt. I said why not, let me try it. As soon as i did,the bolt came out like nothing ever happened!
Old Feb 9, 2003 | 01:04 AM
Stripped Honda's Avatar
99-0104
Default Re: Stripping IM Bolt: Pic: How To? (smokey2.0)
12 point sockets are **** for most car repairs i only use 6 point and rarely strip a bolt .......
try the 6 point and if it dont fit hamer it on and try to take it out with a breaker bar
last resort
if that dont help then get a good chisel and hammer at the edge to make it loosten it this usually will loosten it then just put a vice grips or plyers and take it off ... after you break it loose of course ... on and you can heat it up first also that helps alot
Old Feb 9, 2003 | 08:28 AM
red92s's Avatar
Default Re: Stripping IM Bolt: Pic: How To? (Stripped Honda)
http://cgi.ebay.com/ws/eBayISAPI.dll...category=29527
vtec_crazy
Nov 30, 2014 05:07 PM
B_Swapped93
Sep 14, 2013 12:23 AM
ej888
Jun 12, 2010 08:28 PM
Ash J. Williams
May 12, 2004 07:46 PM
is3oo
Oct 4, 2003 01:48 PM
