Differences in ITR cams.
Old Feb 7, 2003 | 06:21 AM
IC x Prince's Avatar
New User
Default Differences in ITR cams.
I know that the 00-01 USDM ITR cams have a more agressive VTEC lobes. Is there a difference between the 97 JDM ITR cams and the USDM? TIA.
Old Feb 7, 2003 | 06:40 AM
RTW DC2R's Avatar
Default Re: Differences in ITR cams. (UltraPrince)
search man, there are a ton of threads about ITR cams.
Old Feb 7, 2003 | 07:07 AM
New User
Default Re: Differences in ITR cams. (RTW DC2)
Thanks, I did that but didn't up with anything about 97 jdm itr cams. so is it safe to say they are the same as 98spec?
Old Feb 7, 2003 | 07:19 AM
Rdriver's Avatar
I don't think they are the same. The 98 spec R has CTR cams don't they. The 98 spec would have been produced in 1997. The 97 R would have produced in 1996....Right??????
Old Feb 7, 2003 | 01:30 PM
frankdatank's Avatar
Default Re: Differences in ITR cams. (Rdriver)
i think that the 98 up jdm cams are the same aggressive cams that are in the usdm 00 itr. im not positive though.
Old Feb 11, 2003 | 04:46 PM
96dc2's Avatar
Default Re: Differences in ITR cams. (hybridcoupe97)
from Michael Delaney's VTEC cam artice on team-integra.net
CTR cams differ only with the 1997-1999 ITR cams at the intake VTEC lobe duration ( by only 3 degrees more duration ) and ramp angle..that's it!! The intake max. lift are identical. The exhaust cams for both are identical. :
The 2000-2001 ITR cams are identical to CTR cams.
And yet the 2000-2001 ITR's make identical power to 1997-1999 ITR's!!
[Modified by 96dc2, 5:47 PM 2/11/2003]
Old Feb 23, 2003 | 07:04 PM
v00tecsi's Avatar
Default Re: Differences in ITR cams. (96dc2)
Ok then before I buy cams out of an 00 ITR I just want to be sure I am corrct...
00-01 ITR cams = CTR cams???
This is what I have always heard, and told others, I just want to be 100% sure before I buy these cams...
Will I get the exact same results from 00 ITR cams as I will out of CTR cams???
Thanks everyone...
Old Feb 23, 2003 | 09:08 PM
Michael Delaney's Avatar
Default Re: Differences in ITR cams. (v00tecsi)
I don't know but the word identical does mean something in English right? or did I miss something in the translation?
Old Feb 24, 2003 | 06:33 AM
v00tecsi's Avatar
Default Re: Differences in ITR cams. (Michael Delaney)
Yes I am well aware of what you wrote, and I am also well aware of the definition of identical!!! I simply wanted some other peoples opinions or views, or maybe even a chart that has the specs on each of the cams...
I see the quote from your article, and thats great, but I'm sorry that I wanted some more people to back it up....After all, you can't believe everything you read online...
I'm not doubting you at all, I just wanted some more proof before I go out and spend all that money...I would hope you could understand that...
Old Feb 24, 2003 | 07:30 AM
EK Ferio's Avatar
I got an brand new CTR intake cam for sale cos I joust bought the Toda B. If you interest, let me know.
[Modified by EK Ferio, 4:32 PM 2/24/2003]
Old Feb 24, 2003 | 07:35 AM
JDM CTR '00's Avatar
Default Re: Differences in ITR cams. (EK Ferio)
here is what i have check it out
http://www.allmotorhonda.com/techpages/camspecs.htm
Old Feb 24, 2003 | 09:31 AM
v00tecsi's Avatar
Default Re: Differences in ITR cams. (ChargedSi99)
Yeah and according to the chart, the CTRs have more duration on the intake side...
Integra Type R 11.5 mm, duration - 240 @ 1mm 10.5 mm, duration - 235 @ 1mm
Civic Type R 11.5mm, duration - 243 @ 1mm 10.5 mm, duration - 235 @ 1mm
Maybe these are specs from a pre-00????
IntegraVTEC
Jan 10, 2006 07:25 AM
PIC Performance
Dec 3, 2004 02:14 PM
akasen8
Jul 24, 2004 10:27 AM
96tegsr
Jun 28, 2003 04:32 AM
red civic standard
Feb 24, 2003 11:25 AM
