lean hesitating problems
Old Feb 23, 2003 | 03:27 PM
Double 06's Avatar
New User
Default lean hesitating problems
Since removing my Supercharger my car was running flawlessly. Even though I never changed the hi-flow fuel pump it was running really rich.
I have only a aem regulator to combat the fuel pump.
Okay, now for my problem. So often, not all the time. I'll be cruising and with the throttle depressed the car leans out, and when I apply throttle it jerks back out of lean conditions.
I think it may possibly be to small of a rubber gromet in the aem regulator, or a faulty regulator. My fuel pressure gauge reads on the money. But the leaning out only really happens when the car is cold. It jerks really bad to lean when I first start the car and I am cruising in and out of the neighbor going really slow. Its like if I don't keep gas applied it leans out.
Any help is appreciated.
I'm trying to get everything running right before spring when I do the turbo install.
Old Feb 23, 2003 | 04:15 PM
PM-Performance's Avatar
Default Re: lean hesitating problems (Double 06)
how do you know itrs lenaing and not too rich ?
stumbling is usuall do to rich conditions
Old Feb 23, 2003 | 04:59 PM
sgT's Avatar
sgT
Default Re: lean hesitating problems (itr206)
if you are reading an a/f gauge, did you know that when it goes really rich the a/f meter will read LEAN??
Old Feb 24, 2003 | 06:39 AM
Double 06's Avatar
New User
Default Re: lean hesitating problems (sgT)
I didn't know that. Yes the a/f gauge does go beyond red. The are no lights lit. After pressing the gas it jerks and goes to rich 2 to 3 green. It would be hard for me to go to the dyno, unless I could get it to do it while on the rollers. I even took it to the dealership, but they couldn't find nothing wrong because it happen to stop by the time I got there. Atleast when I go full throttle it runs good. My under hood fuel gauge is set to 58-60 psi, but I have no clue what its doing when this is happening.
Old Feb 24, 2003 | 07:19 AM
really ? mine seems to read rich whether im rich or lean . . . i realized that was an expensive light show i bought
no biggie though. i have access to a wideband so i can actually check everything if i think sometihng funny is up with my car.
Old Feb 24, 2003 | 09:47 AM
sgT's Avatar
sgT
and you cant back the pressure down to 50?
GSlowR
Aug 16, 2007 07:12 PM
CO_CReX
May 8, 2007 06:03 PM
imskatencrzy
Apr 4, 2007 03:42 AM
bluesi00
Sep 7, 2004 10:20 PM
HarryB
Mar 28, 2002 08:05 AM
