Differences in ITR cams.
search man, there are a ton of threads about ITR cams.
I don't think they are the same. The 98 spec R has CTR cams don't they. The 98 spec would have been produced in 1997. The 97 R would have produced in 1996....Right??????
from Michael Delaney's VTEC cam artice on team-integra.net
CTR cams differ only with the 1997-1999 ITR cams at the intake VTEC lobe duration ( by only 3 degrees more duration ) and ramp angle..that's it!! The intake max. lift are identical. The exhaust cams for both are identical. :
The 2000-2001 ITR cams are identical to CTR cams.
And yet the 2000-2001 ITR's make identical power to 1997-1999 ITR's!!
[Modified by 96dc2, 5:47 PM 2/11/2003]
Ok then before I buy cams out of an 00 ITR I just want to be sure I am corrct...
00-01 ITR cams = CTR cams???
This is what I have always heard, and told others, I just want to be 100% sure before I buy these cams...
Will I get the exact same results from 00 ITR cams as I will out of CTR cams???
Thanks everyone...
Thanks everyone...
Yes I am well aware of what you wrote, and I am also well aware of the definition of identical!!! I simply wanted some other peoples opinions or views, or maybe even a chart that has the specs on each of the cams...
I see the quote from your article, and thats great, but I'm sorry that I wanted some more people to back it up....After all, you can't believe everything you read online...
I'm not doubting you at all, I just wanted some more proof before I go out and spend all that money...I would hope you could understand that...
here is what i have check it out
http://www.allmotorhonda.com/techpages/camspecs.htm
Yeah and according to the chart, the CTRs have more duration on the intake side...
Integra Type R 11.5 mm, duration - 240 @ 1mm 10.5 mm, duration - 235 @ 1mm
Civic Type R 11.5mm, duration - 243 @ 1mm 10.5 mm, duration - 235 @ 1mm
Maybe these are specs from a pre-00????
IntegraVTEC
Jan 10, 2006 07:25 AM
