CTR or not
Old Feb 6, 2003 | 07:52 PM
NightHawkC5's Avatar
Default CTR or not
My friend bought a JDM Gsr with CTR cams and cam gears. What is the easiest way to tell if they are actually CTR cams and not something else?..................thanks
Old Feb 6, 2003 | 08:30 PM
TimoneX's Avatar
New User
Default Re: CTR or not (NightHawkC5)
Well there was a site that had very detailed pics of the different Honda Vtec cams, but the one I had bookmarked is now a dead link. I suggest searching the net, someone else must have this posted. I recall they had different #s of rings around one end. I was worried about the same thing when I bought some used ITR cams, and I verified them with the # of rings.
Old Feb 6, 2003 | 09:35 PM
TimoneX's Avatar
New User
Ah...someone's on it.
https://honda-tech.com/zerothread?id=407986
Old Feb 10, 2003 | 07:08 PM
Default Re: CTR or not (TimoneX)
Is there a way to tell without the cam being out of the car
Old Feb 10, 2003 | 07:12 PM
civicbro's Avatar
EMIN MORITTTT KUNEM!
Old Feb 10, 2003 | 08:29 PM
Lookincrazy's Avatar
Old Feb 10, 2003 | 09:55 PM
TimoneX's Avatar
New User
Well you wouldn't necessarily have to remove the cam from the car, but you'd likely have to remove the valve cover and perhaps the distributor for positive ID. Do it the next time you set your valve lash.
Old Feb 11, 2003 | 12:37 PM
I took the valve cover off but could not see the treads because its inserted in the side so what should i do
Old Feb 11, 2003 | 01:04 PM
TimoneX's Avatar
New User
I believe the marking are right at the distributor slot on the intake cam. You'll almost certainly have to remove the distributor to see them.
Old Feb 11, 2003 | 02:11 PM
Katman's Avatar
there's really no way to tell if you have 'R' cams while they're on the car, its very hard to tell. the only real way is to take the cam journals off the distributor-side(s) of the camshaft's to see the markings.
btw. I have updated pics I took of 'R' cams, and I'll be redoing my VTEC cam spec page soon.
http://ff-squad.com/VtecCams.htm
Old Feb 11, 2003 | 05:13 PM
Default Re: CTR or not (Katman)
is it safe to take the cam journals off as in will i be able to put it back because i was thinking to take the cams out but im not sure i could put it back in so i didnt mess with it
Old Feb 11, 2003 | 05:32 PM
Katman's Avatar
I would suggest NOT to take the cams out if you've never taken them out before and have no knowledge of doing so. Although, you could have someone who has experience in B-series engines, supervise you.
[Modified by Katman, 6:32 PM 2/11/2003]
mugenDA9 lover
Mar 1, 2007 03:39 PM
allstockb18c
Aug 3, 2005 04:39 PM
BLK99VTECR
Mar 17, 2005 09:16 AM
HybridIntegra
Jan 16, 2004 12:06 AM
StinkyTofu
Jan 4, 2002 09:35 AM
