Timing belt problem?
Old Feb 6, 2003 | 07:39 PM
tub_sephiroth's Avatar
Default Timing belt problem?
Have anyone ever heard what a motor sounds like after a timing belt change and you are off by a tooth?
I recently change my timing belt and right when I start the car, the rpm jumps up to 3k and gradualy moves down. When it's warm and it's at idle, the motor shakes like it's going to die lie when the rpm is too low, but it sits at around 800. Any info will help. Thanks.
Old Feb 6, 2003 | 07:50 PM
tilt's Avatar
Default Re: Timing belt problem? (tub_sephiroth)
It can sound normal. You can tell if it is off a tooth cuz there will be very little power when you try to accelerate.
Old Feb 6, 2003 | 08:38 PM
TimoneX's Avatar
New User
Default Re: Timing belt problem? (tilt)
I would reference the crank pulley marks to the cam pulleys, just to make sure you're not off a tooth. Have you checked your ignition timing lately?
Rost
Jul 3, 2009 09:51 PM
P1mpSlap
Jan 7, 2004 10:50 PM
dreweg
Jul 14, 2003 10:33 AM
PrecisionH23a
Aug 14, 2002 05:16 AM
vti-R
Jun 18, 2002 06:33 AM
