Help!!!!!!!!!!!!!!!!!!
Old Feb 6, 2003 | 03:56 PM
Tee Jay's Avatar
Default Help!!!!!!!!!!!!!!!!!!
I just tried to adjust my valves............
I used the feeler and made sure it all fit good.
After every was finished with I put everything back together.
When I started the engine it was loud as f#$%!!!
What did I do wrong?
Old Feb 6, 2003 | 04:01 PM
globlctzn's Avatar
Default Re: Help!!!!!!!!!!!!!!!!!! (CrX_HF)
Did you re-tighten the screws that hold the adjustment nuts in place when you were done?
Old Feb 6, 2003 | 04:15 PM
Tee Jay's Avatar
Default Re: Help!!!!!!!!!!!!!!!!!! (globlctzn)
Yes...........
Old Feb 6, 2003 | 04:45 PM
globlctzn's Avatar
well, if they are louder now then they were before you started, you screwed up somewhere. Are you using inches or milimeters on your feelers? Could you possibly could have gotten the two mixed up?
Old Feb 6, 2003 | 04:56 PM
Tee Jay's Avatar
mm
Old Feb 6, 2003 | 08:03 PM
IN VTEC's Avatar
Too loose. Try again.
Old Feb 6, 2003 | 08:34 PM
TimoneX's Avatar
New User
Default Re: Help!!!!!!!!!!!!!!!!!! (IN VTEC)
Did you recheck all of them after you adjusted them and tightened the locknuts? They mysteriously seem to move sometimes.
Old Feb 6, 2003 | 09:33 PM
1SlowB16EF's Avatar
im curious to see what procedure you used...
Old Feb 7, 2003 | 11:28 AM
blueeg's Avatar
did you let the engine cool down and did u rotate the crank to tdc when u adjust the valves on each of the cylinders?
littleblue
Aug 10, 2008 05:08 PM
Bad Teggy
Nov 1, 2005 05:33 PM
1.7na
May 31, 2004 07:12 PM
Tee Jay
Feb 7, 2003 12:24 AM
