mods for daily driver?
Old Feb 6, 2003 | 06:57 AM
dip-set's Avatar
Default mods for daily driver?
as tittle says...96 se...actually looking for the best header/exhaust setup...waiting on the v2 aem cai to drop for intake...im looking into the itr catback for the exhaust..but what year itr exhaust is the one i will need...
"i do not want a loud *** annoying exhaust"...a nice buzz at WOT is ok
suspension set up...
dont want it slammed...maybe nice 1 inch drop with decent shocks..i will be adding both upper strut tower braces..most likely nuespeed and the bsq itr rear swaybar install..other than that i would like to swap out all bushing related to suspension to maybe reduce rattles and thuds from worn bushings...all setups will be considered and the mojority will be the chosen set up......also i was thinking itr spings on koni reds..non adjustable..i dont wanna be bothered with playing with the adjustments...
i dont wanna choose these setups by myself as i have no idea what the pros and cons would be of them..so i turn to you guys/girls for advice from the experienced..
thanks a million...
[Modified by teg-your-it, 11:05 AM 2/6/2003]
Old Feb 6, 2003 | 08:33 AM
OC 335i's Avatar
Default Re: mods for daily driver? (teg-your-it)
What car? 96 se integra?
I assume integra since you are looking for an ITR exhaust. Get a JDM Header/CAT if you are looking for an ITR catback exhaust. A nice relatively quiet exhaust is the APEXi Worldsport.
I personally like Eibach springs for a nice ride with some Koni or whatever shocks. You can also get Ground Control Coilovers (springs are made by Eibach). If you want to go a more expensive route there's many different coilover systems to use...
Old Feb 6, 2003 | 09:52 AM
dip-set's Avatar
Default Re: mods for daily driver? (MEGA EK)
ok..but i need to know what brands and which particular set of springs are going to give me that 1 maybe 1 1/2 inch drop im looking for...actually im hoping to get an answer from someone on here whos set up now is similar to what im looking for and possibly a pic or two of how there car looks with that set up...
as far as the jdm header/cat/itr exhaust...where can this be purchased...and will it bolt right on or customized to fit ...
anyone..thanks..
[Modified by teg-your-it, 1:53 PM 2/6/2003]
Old Feb 7, 2003 | 08:57 AM
dip-set's Avatar
gotta be kiddin me right...a numbnut can ask hoe do u change your oil and get a 100 replies but i ask mods fo a dd and get 1...
Old Feb 7, 2003 | 09:20 AM
timmy8151's Avatar
If you want ~ 1" drop, I'd go with H&R OE's. They'll give you about a .75" drop, which is similar to that of an ITR.
I have an ITR catback on my LS and I'm using the stock cat. Any year of the USDM ITR catback will fit your SE.
For a daily driver, I/H/E should give you good increased performance without sacraficing reliability. Personally, I'm going to go with a Comptech 4-2-1 and an Icebox to complete the H & E on my daily driver.
Old Feb 7, 2003 | 09:46 AM
dip-set's Avatar
Default Re: mods for daily driver? (timmy8151)
geezus thank u...i was looking at the h&r oe sport spring but thought maybe it wasnt enough of a drop..but im pretty sure those are the ones i"ll run with...match them up with koni reds should give a decnt ride plus rear itr sway and nuespeed front and rear strut tower braces...also is there an aftermarket company that i can buy rubber bushing (all that play a part in ride comfort)or get oem...i dont want the ones that stiffen up the ride..just replace old with new rubber..and what bushing would i exactly be replacing that have to do with ride comfort so i know which ones to order...
as for the itr exhaust..is it a direct bolt on or lil mods needed..and i was thinking of the comtech header also...whats the difference in the 4-2-1 and 4-1...the ls needs more high end power where it starts fall off..
intake: im waiting for the v2 aem cai to come out...
thanks..
Old Feb 7, 2003 | 01:59 PM
RABBIT9's Avatar
Eibach Pro-Kit
Old Feb 7, 2003 | 03:04 PM
lshobo's Avatar
haha, dude you've already listed a bunch of stuff you are considering. have you performed a search on these various items? i was able to find information and and choose all my parts based solely on research. you said you don't know the pros/cons, but that's what a search will help you find out.
on another note. i would choose hr sports. 1.5-1.75 inch drop - a little more aggressive, but definitely streetable. if you can't do koni adjustables, reds are cool. but it really helps to have adjustability..the difference between comfort and discomfort, especially if you are going with the sport/race drop. imo, if you plan on doing any aggressive driving, go for the sport drop at least
aem intake, comptech 4-2-1, and the itr catback as previously suggested and call it a day.
[Modified by lshobo, 12:06 AM 2/8/2003]
Old Feb 10, 2003 | 05:01 AM
dip-set's Avatar
Default Re: mods for daily driver? (lshobo)
i would like the sport drop but dont want a real hard ,rough ride,thats why im considering the oe sport drop lil softer i assume..i dont know yet...thats why im asking for YOUR opinions as to the difference in the ride feel of the 2...as far as adjustable shocks..i dont wanna be bothered playing with the adjustments...
positive feedback appreciated...thanks
Old Feb 10, 2003 | 05:12 AM
kyle h.'s Avatar
have you even researched this yourself? most companies will have all the specs you need and feedback from real customers. you come here and ask for our experiences, maybe we dont have the ones you're looking for? and thats why you got no replies.
triple
Mar 31, 2006 07:20 PM
mrdeadman
Mar 20, 2006 03:56 PM
JayThrilla
May 10, 2005 09:57 AM
spun Vtec
Dec 22, 2002 03:28 PM
JM Performance
Apr 23, 2002 05:01 PM
