GSR crank in LSVtec ? (searched)
I was wandering if I could use the GSR crank in a LSVTEC setup to correct (or improve) the rod stroke ratio? Does it fit in the LS block or does it need to be machined to fit? Since the bore on the LS is the same as on the GSR and the stroke would be changed with the crank would the LS block stand up to higher revs (like a stock GSR block)? Thanks for any help
[Modified by EGCIV, 2:35 AM 2/6/2003]
it will be a gsr again minus the oil squirters.
That would defeat the whole purpose of LS/VTEC, which is the longer stroke of the LS crank.
03EM2guy
19
Mar 28, 2011 06:00 AM
