2.26 L GSR Engine
Old Feb 4, 2003 | 08:33 PM
Mister Fixer's Avatar
Default 2.26 L GSR Engine
Crower offers a stroker kit for the B18C that strokes it out to 2.26 L... With high-compression pistons, oversized valves, new springs and retainers, and a more aggressive cam (Duration Int- 297/Exh- 287, Lift .446/.465), as well as some bolt-ons (Performer-X Intake Manifold, sensible cold air, other misc.) and a good Hondata tune up, what horsepower gains could I expect? This is the set-up I want to eventually run on an all-motor 5th Gen Civic Hatch swap. I was thinking at first of going supercharger/turbo, but I think really hardcore all-motor street set-ups are definitely more unique, if not more durable.
[Modified by Mister Fixer, 5:34 AM 2/5/2003]
Old Feb 4, 2003 | 08:43 PM
texan's Avatar
Default Re: 2.26 L GSR Engine (Mister Fixer)
If they aren't stuffing a seriously long rod in there, the r/s ratio of this setup is at or near 1.4:1. If they are they're probably having to compromise the oil control ringland, and in either case I'd certainly hesitate to call this a reliable setup (over the long term). If you're so interested in displacement, why not either start with a Dart B20+ block or just get an H22???
Old Feb 4, 2003 | 08:47 PM
Default Re: 2.26 L GSR Engine (texan)
What is the rod length for a B18C? I was trying to find it earlier, but I guess I didn't look hard enough. The stroke for the kit is 95mm, btw.
The main reason I would go with the B18C is parts avaliability. It is a very well-supported platform, obviously.
Old Feb 4, 2003 | 08:56 PM
texan's Avatar
a B18C1 rod is 137.9 mm long, measured center-center
The dart B20+ block has a 226mm deck, vs. the 212mm B18C1 deck. Using this block with it's avaliable 84.5mm bore would give you 2.13L with that 95mm stroke. Even using a standard wrist pin location you'd get a 1.56:1 rod ratio.
What are you planning to use this engine for?
Old Feb 4, 2003 | 08:59 PM
Mostly just cruising, with the occasional stop at the track... More than anything, though, I'm an enthusiast. I like building and taking apart cars.
Old Feb 4, 2003 | 09:00 PM
texan's Avatar
Then do it right and don't skimp on the geometry. I would be willing to bet you'll have cylinder sealing problems in no time with the Crower 95mm crank on a B18C1 block.
b18cgsr_eg92
Aug 18, 2014 08:32 AM
spoon93
33
Nov 9, 2011 08:14 AM
Touge Tuning
22
Oct 26, 2006 07:24 AM
slowteg550
Apr 16, 2006 03:55 PM
compwc18
Dec 6, 2002 12:30 AM
