GSR Build up
Old Feb 4, 2003 | 07:38 PM
CATCH DIS HATCH's Avatar
Default GSR Build up
I have a GSR block and dont know what to do with it. I want to build it up. I dont really want to spend that much. I just want to smoke peeps on the streets. I dont really want turbo tho. I heard of boring out the block to 84.mm...So give me some ideas on building up my GSR block. I want HP...................thanks
Old Feb 4, 2003 | 07:40 PM
civicbro's Avatar
Default Re: GSR Build up (Red gsr209)
vtec controller and some cams... helped me out alot
Old Feb 4, 2003 | 07:42 PM
Al Bundy's Avatar
How much money to spend then? Getting new sleeves to 84.5mm bore is going to cost you.
Old Feb 4, 2003 | 08:04 PM
Default Re: GSR Build up (Al Bundy)
can I just bored my block without getting new sleeves? I was wondering if I can get some JDM integra type r O/S piston. Well, get me some more ideas....thanks
Old Feb 4, 2003 | 08:34 PM
Al Bundy's Avatar
You can bore out to 82mm max i believe, but that makes your sleeves weaker. If you want to do it right, get it resleeved. That should cost $750-1000 for sleeves, then you gotta get bigger bore pistons, stronger rods, gaskets/seals/bearings. So it will add up.
If all that you are getting is jdm itr pistons 25 over, then stock sleeves would be okay.
Old Feb 4, 2003 | 08:48 PM
SIReg9's Avatar
Is it a GSR short block or longblock?
I am doin mine right now.... And im puttin CTR pistons in there with a B16 head, That should give me about 12:1 compression. Then im goin with a Skunk2 valve train and crower cams,Prelude injectors, ITR fuel pump, And an ITR manifold down the road.
Thats a pretty cheap buildup that should yeild some ok power
Old Feb 5, 2003 | 10:21 AM
Default Re: GSR Build up (SIReg9)
Yeah, its a GSR block that I have. So, CTR piston are better then ITR piston? Wont it have a high compression. I might have to use a higher octane in then 92??? Im going to put a Integra type r head in my GSR block. With one would be better, to mill your head or just get thinner head gasket????
Old Feb 5, 2003 | 11:14 AM
SIReg9's Avatar
The CTR pistons in a GSR block with an ITR head will have about 12:1, there shouldnt be a problem running that on 92 octane.
And personaly i wouldnt mill my head for jack ****, and i dunno if i would even run a thinner head gasket. Im all about the honda factory parts.
Old Feb 5, 2003 | 05:30 PM
Hey, how bout if I get some O/S CTR piston in my GSR block? What do you think????
Old Feb 5, 2003 | 05:44 PM
ExospeedAMcrx's Avatar
check out our engines page.. the race block section.. that will give you an idea of how much diff stages of blocks cost.
Old Feb 5, 2003 | 06:20 PM
polymath's Avatar
I'm running std bore CTR slugs in a B18c...B16a head and Toda B's. It makes good power. Haven't had a chance to dyno it...92 octane should be fine. Make sure you have fuel and you'll be good.
Got my CTR pistons from ITRinEJ1
[Modified by Coyote1800cc, 9:21 PM 2/5/2003]
GoSickemRobert
May 1, 2011 09:03 PM
12secdc2
Dec 4, 2008 09:25 PM
lil98civi
Jun 17, 2008 06:41 AM
GSR95T
Sep 19, 2004 07:54 PM
GSRacer
Nov 8, 2001 11:31 AM
