Easy mods to add horsepower?????
Old Feb 5, 2003 | 03:49 PM
civic596's Avatar
Default Easy mods to add horsepower?????
Just looking for any easy mods to add horsepower and better times at the track. (99 Si) Already has CAI, header, and ACT street/strip clutch. Running 15.5 in Arizona that is.
Old Feb 5, 2003 | 03:57 PM
sslude's Avatar
Default Re: Easy mods to add horsepower????? (civic596)
exhuast, intake manifold, throttle body, camgears, cams, P&P, ECU, VAFC, pulleys, tires, wheels (lightweight), and dyno tune everything. should put you into the 14's or less
Old Feb 5, 2003 | 04:02 PM
civic596's Avatar
Default Re: Easy mods to add horsepower????? (sslude)
One thing at a time. Probably go for the cams first. (CTR cams), and then exhaust and so on.
Old Feb 5, 2003 | 04:10 PM
BudaKai's Avatar
Cams shouldn't be first. You should work your way up to big mods like cams.
Old Feb 5, 2003 | 04:23 PM
marc.ejay-twenty's Avatar
Default Re: Easy mods to add horsepower????? (tzsir)
i agree with tzsir...you'll see more of a power difference than you would think just from an itr intake mani and itr tb. also, what goals are you looking for in terms of power and eta? cuz ctr cams are really mild and after awhile, you'll get tired of the power they make in a 1.6. i suggest skunk stage 2's...great power for a great price. dyno tuning is key.
Old Feb 5, 2003 | 04:48 PM
Angry Joe's Avatar
No such thing as an easy way to get power. Do some reasearch and plan on spending a lot of time, money or both. Personally I'm spending money on autocrossing school instead.
Old Feb 5, 2003 | 04:57 PM
90_Civic_Hatch's Avatar
you need to tell us what your end goals is for your car. are you going NA, FI, no2 etc... if you do this we can point you in a better direction for modding the car in an order that will be suitable for your needs
Old Feb 5, 2003 | 05:43 PM
EuRoBrO's Avatar
CTR cams on B16's are awesome. You will feel a major diff. in horsepower. Get a ECU and u can really take advantage of them.
Old Feb 5, 2003 | 05:58 PM
Spartanic's Avatar
Check out this site for anything you need.
http://www.motorgearsonline.com
Old Feb 5, 2003 | 06:20 PM
civic596's Avatar
Default Re: Easy mods to add horsepower????? (Spartanic)
Just wanting to honestly run the quickest time I can in this car without changing the way it runs. I want to use it as a daily driver as well. I don't want the idle to be weird and such.
polishedturd
Feb 1, 2008 10:49 AM
gunnerman
May 8, 2007 06:01 PM
smkngsr
16
May 15, 2005 10:49 AM
1994GSR
Dec 9, 2004 08:28 AM
sharkey65a
Jan 7, 2003 12:55 PM
