Timing Belt
Old Feb 3, 2003 | 04:56 PM
rivvin's Avatar
New User
Default Timing Belt
I need to relace my timing belt soon. I was just wondering what you guys are paying to replace them. What's the most I should pay? Should I go to the Acura shop? Thanks for any info.
Old Feb 3, 2003 | 04:58 PM
EL Vap133's Avatar
Default Re: Timing Belt (rivvin)
If you go to the dealer or a big shop they will overcharge you...
Old Feb 3, 2003 | 05:24 PM
NeoGSR's Avatar
Default Re: Timing Belt (Vap133)
i'm bringing mine to a local shop that uses acura parts....he'll do the 90k tune-up which includes timing belt, drive belts, waterpump, valve clearance, cam seals, crank seal, valve cover gasket, cap, rotor, wires, plugs and some other little stuff for $800 including acura parts......not expensive, not cheap, but it'll beat the dealer and i don't want to tackle this job myself...yet....
Old Feb 3, 2003 | 05:35 PM
HondaJon's Avatar
Default Re: Timing Belt (NeoGSR)
You'll have to have a first time replacing a timing belt, so why not try it now? You'll save hundreds on the labor costs and learn alot in the process.
If you haven't gotten one already, you should pick up a Helm's manual.
Depending on where you live, there should be a few H-T guys around that would be more than willing to help you. The only payment most of them require is a few beers and maybe some food.
Good Luck,
JP
[Modified by HondaJon, 6:36 PM 2/3/2003]
Old Feb 3, 2003 | 05:40 PM
97hb's Avatar
I am going to have to agree with you there.
Old Feb 3, 2003 | 08:09 PM
rivvin's Avatar
New User
Default Re: Timing Belt (97hb)
Yea okay I know all about the dealers but about how much are you guys paying?
Old Feb 4, 2003 | 07:34 AM
dip-set's Avatar
im still trying to find someone from h-t in my area to help me with my 90k maintenance...or should i say i wanna help and learn from a h-t member in my area ...
Old Feb 4, 2003 | 07:52 AM
jabroni95gsr's Avatar
Default Re: Timing Belt (teg-your-it)
$800 for all of that is a ripoff.
I paid a local honda specialist $450 for everything you mentioned....
Go to a local honda specialist...its the best thing to do. Dealers make everything sound so complicated and overcharge.
Old Feb 4, 2003 | 07:58 AM
bri's Avatar
bri
how about we organize a jersey maintenance day? i could get my timing belt done too, willing to help out if we can get someone who knows how to do it to come...
Old Feb 4, 2003 | 08:19 AM
Eva01's Avatar
Default Re: Timing Belt (bri)
My dealer had a special for a 495$ timing and waterpump replacement. But typically I hear prices btn $600-800 at the dealer.
Old Feb 4, 2003 | 08:28 AM
Trac226's Avatar
Default Re: Timing Belt (Eva01)
My shop usually does it for 500-600 which includes the water pump, timing belt, drive belts, tensioner, valve adjustment, tune up, and all seals associated. Imo, a whole lot more than what any dealership would do. It's a good diy project if you have someone experienced to help you out. Good luck and take it easy on the car just in case.
Old Feb 4, 2003 | 08:33 AM
allmotorls95's Avatar
Default Re: Timing Belt (Trac226)
ive done mine once and it was a good experience...but a couple of months i had mine done for 250..without parts..
kai06
Sep 19, 2011 12:52 PM
doostin
Feb 1, 2009 04:45 PM
typeS
Jan 5, 2007 09:14 PM
this name is gone
Nov 13, 2004 10:45 AM
Mike95lude
Apr 21, 2003 10:51 AM
