Help! shifting problem....used search
Old Feb 3, 2003 | 09:46 AM
the barst's Avatar
Default Help! shifting problem....used search
shifting is notchy in all gears but really has trouble going into 3rd and 4th at higher rpm's especially after car is hot. changed tranny oil, no short shifter, new shifter bushings. could it be the clutch? it is an exedy with 30k on it.
Old Feb 3, 2003 | 10:00 AM
allmotorls95's Avatar
Default Re: Help! shifting problem....used search (the barst)
sounds like ur one of ur springs is gone..
Old Feb 3, 2003 | 10:34 AM
Eva01's Avatar
Default Re: Help! shifting problem....used search (allmotorls95)
3-4th Syncro is probably fried. I think an exedy will last longer that 30k unless you beat the everliving hell out of it.
Old Feb 3, 2003 | 11:00 AM
the barst's Avatar
Default Re: Help! shifting problem....used search (Eva01)
it isn't butter in any gear anymore. is it common for more than one gear's syncro's to go at the same time?
Old Feb 3, 2003 | 11:01 AM
NeoGSR's Avatar
does it grind, or just feel like mush when you shift?
Old Feb 3, 2003 | 11:36 AM
JimBlake's Avatar
Seems unlikely that all your synchros went at the same time. That's why I'd suspect the clutch. If its getting thin it might be warped. Then it drags & doesn't COMPLETELY disengage.
Old Feb 3, 2003 | 11:40 AM
Eva01's Avatar
Not really. It's usually the 3-4syncro that goes. Are you experiencing any clutch chatter or problems disengaging? Mushy pedal feel?
Old Feb 3, 2003 | 11:46 AM
the barst's Avatar
no grinding or problems staying in gear. Like just really notchy for the most part, but if I bring it close to redline sometimes the shift just won't go into gear. Feels like if you were just sittng in the car idling and tied to put it in gear without pushing in the clutch. It just won't let you. no slave or master cylinder leaks, fluid is full and was bled not too many ages ago.
Old Feb 3, 2003 | 11:48 AM
Chris's Avatar
Sounds like Synchros...
remember folks.. 1-2 share same Synchro, 3-4 are same as well, and 5th and Reverse..
but in all gears??? could be clutch?
Old Feb 3, 2003 | 12:10 PM
the barst's Avatar
Default Re: Help! shifting problem....used search (Chris)
what else could it be inside thte transmission that would cause this?
ohiohonda
Feb 21, 2006 11:11 AM
turbo gsr
Oct 2, 2005 06:37 PM
dohcdelsol
Jan 7, 2005 10:11 PM
JdMCiviCCupE
Nov 12, 2003 12:23 PM
