B20 head on B18A block?
Old Feb 2, 2003 | 09:34 PM
91teg's Avatar
Default B20 head on B18A block?
Would this work? would it be a disadvantage? is the head the same as a 94-00? Thanks
Old Feb 2, 2003 | 10:17 PM
GirlyGS-R's Avatar
Default Re: B20 head on B18A block? (91teg)
its the same head.
Old Feb 4, 2003 | 11:46 AM
slopok's Avatar
there is probally no point..just keep the b18 or the b20
Old Feb 4, 2003 | 01:47 PM
Mr Miyagi's Avatar
The B20 head is the same as found on the b18b engine and it will fit right onto a b18a block, no problemo.
Old Feb 11, 2003 | 07:35 PM
Circuit Star-29's Avatar
Default Re: B20 head on B18A block? (Mr Miyagi)
I'VE SEEN THIS SO MANY TIMES!!!! The B18A/B and the B20B are almost identical. Except for the odvios .2 liters and 11% more torque from the B20B.
Old Feb 11, 2003 | 07:44 PM
Jspd's Avatar
Default Re: B20 head on B18A block? (nathan atwell)
why would you want a b20 head? i would go b20 block and the b18a head. better combination in my oppinion. what are your goals? are you going NA, or Forced Induction?!
[Modified by Jspd, 10:45 PM 2/11/2003]
Old Feb 11, 2003 | 11:11 PM
integobsession's Avatar
Old Jul 7, 2005 | 02:33 PM
Colt Seavers's Avatar
Default Re: B20 head on B18A block? (integobsession)
You can't use a b20 head on a b18a,b block, how would the head gasket seal.
You can use a b18 head on a b20 block. Any way it would be alot better to just
go straight b20. The intake valves in the b20 head are the same size as vtec intake valves.
Jhobs3
Feb 4, 2013 10:45 AM
mrxracing
Jun 6, 2004 08:23 PM
PrOjEcTpImPcIvIc
Nov 12, 2003 07:08 AM
AudioXtremes
Mar 31, 2003 02:47 PM
The G2 Racer
Nov 14, 2002 02:10 PM
