B20 head on B18 block???
Old Mar 28, 2003 | 03:47 PM
AudioXtremes's Avatar
Default B20 head on B18 block???
Ok, I was just wondering if the porting is the same for both the b20 and the b18 cause I have a b20 head I can put on my b18a to lower comp. to run more boost. Would this work? I was thinking I was gonna run 9lbs on the b18 but now I might run 11-12 with the b20 head if it lowers comp. Thanks.
Old Mar 30, 2003 | 04:27 AM
Default Re: B20 head on B18 block??? (AudioXtremes)
anyone???
Old Mar 30, 2003 | 06:04 PM
JDMPARTS4U's Avatar
in theory it will work I was thinking the same thing just make sure you get the right head gasket
Old Mar 30, 2003 | 06:18 PM
UberTeg's Avatar
Default Re: B20 head on B18 block??? (JDMPARTS4U)
The b20 head is EXACTLY the same as the b18. Even the dome and head gasket is 81mm just like the b18 head.
Old Mar 30, 2003 | 07:02 PM
Speed PHreak's Avatar
Default Re: B20 head on B18 block??? (UberTeg)
Yes. no difference. I believe the casting numbers on the head are even the same.
Old Mar 31, 2003 | 04:30 AM
Default Re: B20 head on B18 block??? (Speed PHreak)
I thought the b20 was 84mm? am I wrong?
Old Mar 31, 2003 | 05:11 AM
Drag_On's Avatar
Same exact head.. Yes, wrong..
Old Mar 31, 2003 | 07:19 AM
BoostedSi's Avatar
i thougth the same thing.
Old Mar 31, 2003 | 02:47 PM
Default Re: B20 head on B18 block??? (BoostedSi)
so you mean the head is not 84mm??? Because the block is 84mm. I know that for a fact!
Jhobs3
Feb 4, 2013 10:45 AM
hybrid_vtec
20
Apr 21, 2010 10:22 AM
ekb16a
Mar 25, 2008 08:20 PM
spooncrx91
Jan 27, 2006 06:56 AM
mrxracing
Jun 6, 2004 08:23 PM
