B18A Head on B20 Block
Old Nov 12, 2002 | 07:36 PM
The G2 Racer's Avatar
Default B18A Head on B20 Block
Will a b18a head bolt on to a b20 block? I need to knwo because my friend is selling one.
Old Nov 12, 2002 | 07:41 PM
StorminMatt's Avatar
Default Re: B18A Head on B20 Block (The G2 Racer)
It will bolt on. But it will also hurt performance. The intake ports are MUCH smaller on the B18A head than the B20 (or B18B) head.
Old Nov 12, 2002 | 07:45 PM
Default Re: B18A Head on B20 Block (StorminMatt)
what about having the intake ports enlarged?
Old Nov 12, 2002 | 08:11 PM
InevitableRace's Avatar
Um why would they be bigger on a b20?when they have a smaller cam than the b18?????
Old Nov 13, 2002 | 03:32 AM
Default Re: B18A Head on B20 Block (allmotrb18c1)
Anyone know if the intake ports on the b18a head are smaller or larger then the ones on the b20?
Old Nov 13, 2002 | 06:24 AM
1bad_EF's Avatar
From: On a pile of junked Acuras and Hondas, WI, usa
they might be a little smaller but i would not try to make them bigger for fear of hurting intake airflow velocity(volume goes up pressure goes down). The combustion chambers are smaller on the b18a/b heads because the b20 has a bigger bore size. The smaller size will increase compression a small ammount.
Old Nov 13, 2002 | 08:56 AM
Default Re: B18A Head on B20 Block (1bad_EF)
Then the down fall in performance would be minimal?
Old Nov 13, 2002 | 11:04 AM
Vu's Avatar
Vu
I think the head on the CRV is the same as the LS. Even the quench area is the same(81mm).
Old Nov 13, 2002 | 12:17 PM
LB CRX's Avatar
Default Re: B18A Head on B20 Block (Vu)
if you have the b20 head on the b20 block then leave it alone. like the guy said above, the ports are smaller and it will hurt your performance.
Old Nov 14, 2002 | 02:10 PM
B20Coupe's Avatar
A B20 HEAD AND A B18 HEAD....THE SAME THING!!!
i know from experince, B/C i have ONE!!!
the only difference is that on the b20 camshaft, i belive it has something like .003 higher lift on the intake cam...which wont make any difference so dont mess with it...however you should look into getting retainers and valve springs, the b20 valves have a tendency to float at higher rpm's, which for a b20 is something like 6,800rpm...i have crowers on my b20 (retainers and valve springs) and its SHWAAEEEETTTTT
Jhobs3
Feb 4, 2013 10:45 AM
clevelee
Dec 3, 2008 11:53 PM
oilspot
Nov 13, 2008 08:27 PM
da9wonder
Oct 25, 2006 10:30 PM
91teg
Jul 7, 2005 02:33 PM
