Checking ECU Codes
Old Jan 30, 2003 | 08:25 PM
93EH6
Guest
Posts: n/a
Default Checking ECU Codes
My check engine light is on but i forgot how to check the codes so could someone help me
Old Jan 30, 2003 | 08:29 PM
AutomaticB16's Avatar
Default Re: Checking ECU Codes (autoxdelsol)
go where your ecu is and find 2 green wires with blue ends on then (not on your ecu its next to it somewhere you have to find it). look at the blue thing where there is only 2 holes. then you get a piece of wire and have the wires expose on both ends and place one wire in one hole the other in the other hole and watch your check engine light give you a code.
Old Jan 30, 2003 | 08:31 PM
chillly's Avatar
Take the Engine Diagnostic Plug out of it's plastic dummy plug thingy (plug is up by the glove box in the passenger-side floor board) and take something metal and bridge the gap between the two pins (a paper clip or short length of wire will do), then turn the key to on and see what code the CEL blinks.
Old Jan 30, 2003 | 09:11 PM
93EH6
Guest
Posts: n/a
Default Re: Checking ECU Codes (uncivilCivicinprogress)
Does someone have a list of the codes
rhoades
10
Dec 28, 2009 12:42 AM
94whitegsi
Aug 4, 2006 07:22 PM
b18c4dr
Mar 1, 2006 03:09 PM
allmotorEG-SI
Jul 20, 2004 09:51 PM
RacerXintegra2k
Aug 13, 2002 09:15 PM
