Valve Springs
Old Jan 30, 2003 | 07:53 PM
See Are X's Avatar
Default Valve Springs
Im putting my valve springs back into my 95 GSR head. My question is, does it matter which way the exhaust valve springs go in? I know the intake valve springs are close together on one end and far apart on the other, but I can't really tell if the exhaust springs are the same way.
Old Jan 30, 2003 | 09:42 PM
leadfoot78's Avatar
Default Re: Valve Springs (See Are X)
inner springs are non progressive and it doesn't matter which way you install them, outer springs are progressive and one end of the spring has the coils closser together. I think the end with the coils close to eachother should be on the bottom but I'm not sure. My portflow inners were not progressive I'm pretty sure the stock ones are also but check to make sure.
Old Jan 30, 2003 | 09:45 PM
sgT's Avatar
sgT
Default Re: Valve Springs (leadfoot78)
painted side up
Old Jan 31, 2003 | 05:13 AM
See Are X's Avatar
Default Re: Valve Springs (sgT)
My exhaust side doesnt have inner springs. Are the exhaust spring progressive also???
Old Jan 31, 2003 | 02:13 PM
leadfoot78's Avatar
you should be able to telly by looking at them if they are new the tops of them should be painted but from what i understand you are using the old ones.
Old Jan 31, 2003 | 02:30 PM
erniecars's Avatar
When I swaped my valve springs I put the painted side up but honestly I didnt think it matters because the coils did not look progressive. They looked exactly the same if i flipped them upside down. Besides, I cant imagine why it would matter anyway since the retainers and seats are totally flat. Its not like suspension springs. They just push out. It shouldnt matter which way they go in. Maybe Im totally off.
Old Jan 31, 2003 | 06:26 PM
HEAD's Avatar
I don't think I've ever seen a progressive valve spring what brand are they?
Old Feb 20, 2003 | 06:12 PM
GapxGuy's Avatar
Sushi Buffet Champion
Default Re: Valve Springs (HEAD)
Yeah haven't you heard? I'm getting coilovers so I can adjust to how high I want to rev.
boostedteg4dr
Sep 30, 2008 01:06 PM
RC000E
19
Jun 15, 2007 06:11 PM
Mover
Aug 19, 2003 04:02 AM
