Valve Spring Identification
Old Aug 14, 2003 | 06:04 AM
Mover's Avatar
Default Valve Spring Identification
A while ago, I replaced my stock valve springs/ret with aftermarket springs/ti-retainers. Does anyone remember how the stock springs are oriented in the head of an H22? One end of the springs are painted and the other side has the coils wound tight towards the end.
Also, half(8) of the outer springs are slightly different than the other 8 outer springs. The wire diameters on 8 of them are smooth and the others have a slight ridge.
Old Aug 14, 2003 | 06:30 AM
rsbad454's Avatar
Default Re: Valve Spring Identification (Mover)
i believe the ones that are painted are the intake springs....and of course the smaller springs go inside those.
Old Aug 14, 2003 | 06:39 AM
Mover's Avatar
Default Re: Valve Spring Identification (rsbad454)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rsbad454 &raquo;</TD></TR><TR><TD CLASS="quote">i believe the ones that are painted are the intake springs....and of course the smaller springs go inside those. </TD></TR></TABLE>
All the springs are painted on one end.
Old Aug 14, 2003 | 07:38 AM
rsbad454's Avatar
hmmmm, mine are only painted for intake.........not too sure.
Old Aug 14, 2003 | 01:08 PM
Rocket's Avatar
Honda OE springs are usually progressively wound. The tigher coils should go to the bottom.
Here is a prelude spring. Notice the tighter coils on the bottom.
Old Aug 15, 2003 | 11:50 AM
Mover's Avatar
Default Re: Valve Spring Identification (Rocket)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocket &raquo;</TD></TR><TR><TD CLASS="quote">Honda OE springs are usually progressively wound. The tigher coils should go to the bottom.
Is that the intake or exhaust spring ? There is a slight difference in the shape of the wire diameter (one is ridged, one smooth) for the outer springs. All 16 inner springs look the same but they have different part numbers for intake and exhaust.
Old Aug 15, 2003 | 12:12 PM
Rocket's Avatar
The spring pictured is diamond shape (square instead of round.) I am pretty sure it's an intake.
Old Aug 15, 2003 | 12:19 PM
rsbad454's Avatar
weird....i didnt know this.........i didnt notice the B16A springs were prgressive and had different shape for intake and exhaust?
Old Aug 15, 2003 | 01:29 PM
Mover's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocket &raquo;</TD></TR><TR><TD CLASS="quote">The spring pictured is diamond shape (square instead of round.) I am pretty sure it's an intake.</TD></TR></TABLE>
Did you ever measure what the seat/open pressure was for the Prelude springs ?
Modified by Mover at 6:20 PM 8/16/2003
Old Aug 16, 2003 | 03:31 PM
Rocket's Avatar
I did but at B series specs at 1.320" installed height. I'll have to look at my notes for the numbers. The prelude spring's I.D. is actually a littler smaller than the B-Series.
Old Aug 16, 2003 | 08:10 PM
Mover's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocket &raquo;</TD></TR><TR><TD CLASS="quote">I did but at B series specs at 1.320" installed height. I'll have to look at my notes for the numbers. The prelude spring's I.D. is actually a littler smaller than the B-Series.</TD></TR></TABLE>
It would be interesting to see how OEM rates compare to aftermarket spring rates (even though aftermarket springs have to usually deal with more cam lift/duration).
Thanks for the spring ID in the post above.
Old Aug 18, 2003 | 02:22 PM
Rocket's Avatar
B Series Spring Rates
Most aftermarket springs have tipically have the following rates.
60-70lbs on the seat
200-240 at 12mm lift.
Stock is roughly
55lbs on the seat
165 at 11mm lift
Old Aug 19, 2003 | 04:02 AM
Mover's Avatar
These OEM Type-S springs should approach aftermarket rates.
More reliable to.
http://www.aj-racing.com/JDM-BB6.html
Modified by Mover at 12:42 PM 8/19/2003
Btothe3rdDegree
Mar 8, 2005 08:56 PM
bo0sted
May 28, 2004 01:45 PM
See Are X
Feb 20, 2003 06:12 PM
NoGoSi
Feb 5, 2003 10:20 AM
