sohc vtec swap into 92 civic
hey, whats the best motor to swap into my 92 civic dx?? it has to be sohc vtec. im thinking a d16 from a 93-95 del sol si, but maybe not. also are the d15 vtec's even wroth building, or should i just go for the 1.6L?? thanks.
The d16z6 sohc vtec and the JDM d15b both put out the same power. I believe the JDM d15b is basically a vx block with a z6 head. It makes as much power stock as a d16z6 because of a wilder cam. Either motor would be good. If you are going to buy a complete swap, the JDM d15b can be found with factory lsd.
nah, im sticking with the sohc, and i defenitly want vtec, unless i get bored and do a junk yard turbo, but the money isnt really there right now,
If you cant afford a B16 or B18 I'd say go for the D16Z6. It's a nice ride!!!
With a turbo you can make it go pretty fast..
But if you can wait, just save your money and wait until you can afford the B18... I think that would be the best choice in the long run....
M. Nielsen, Denmark
"I go D-series, N/A all the way!!"
M. Nielsen, Denmark
thats right super d-series, it had 220k miles on the ORIGINAL clutch. the only work it ever had done was a distributer, it was good, but the new D will be even better.
matt, whats this about already having vtec wiring?? like on the ecu??
d16z6 motor is excellent for the price. power to weight ratio is good especially in lighter hatches to make it a mid/low 15'second car.
flat torque curve, weights 100-125lbs less then B18B swap, and makes very simliar power.
your average b18a/b setup will dyno @112-118whp and 105-112lb/ft of torque, while a d16z6 will make about 108whp and about 99-102lb/ft of torque.
while b18b swap will cost over or around $1500, D16z6 swap will set you at about $400-600 or so. for the extra $1000, you can make it putout at least 130whp, and run 14's
D16Z6 all the way.
http://www.geocities.com/dynocenter/95LS_cgaines.html
D16Z6 all the way.
Kevykev
28
Jul 4, 2008 04:40 AM
Super D-series !!!
