Just installed my S-AFC.....
Old Jan 30, 2003 | 01:35 PM
BoostedB20A's Avatar
Default Just installed my S-AFC.....
Ok, I have a 1990 honda prelude. I just installed my s-afc, and I am almost 100% posotive that everything is hooked up correctly. But here is my problem: The ground wire that goes to the ECU is grounding when the key is off, but as soon as I turn the key to the on position, their is no longer a ground. I tested the wires to find this out. Anyone hava any idea why their would not be ground when the key is on? Oh, I forgot to mention, the engine is not in the car right now, could have an effecting on the ground in the ECU? Please help me out. Thank you.
Old Jan 30, 2003 | 01:43 PM
sgT's Avatar
sgT
Default Re: Just installed my S-AFC..... (BoostedB20A)
the transmission ground grounds the ecu.
Old Jan 30, 2003 | 01:49 PM
Default Re: Just installed my S-AFC..... (sgT)
Really? My tranny ground just goes from the tranny, to a chasie ground. Do you think thats my problem? Thanks for your help.
Old Jan 30, 2003 | 01:53 PM
sgT's Avatar
sgT
yep, i would say so.
remember that the sensor grounds go from the ecu, to the engine harness, then to
the engine/trans and then to the chassis.
Old Jan 30, 2003 | 03:24 PM
Sounds good to me man, thanks a ton for your help, now I can sleep tonight. Thanks again.
njkill
Jul 20, 2010 01:43 AM
MrMug3n
Jun 1, 2009 08:38 AM
lude98SH
Aug 30, 2007 08:55 AM
93cavRS
Oct 10, 2006 12:25 PM
suckawillis
Oct 5, 2005 09:00 AM
