code 71,72,73,74
Old Jan 30, 2003 | 08:45 AM
zexteg's Avatar
Default code 71,72,73,74
well today the teg threw 4 misfire codes all at once the car barely starts and wont stay running at all unless u stay on the gas. I put in new oem plugs wires cap and check valve timing and compression ne of ya guys have an idea plz let me know im runnin out of ideas.
thanks gary
Old Jan 30, 2003 | 09:06 AM
LS-hatch's Avatar
Default Re: code 71,72,73,74 (zexteg)
So it threw the misfire codes before and after replacing everything with stock? Any change in the way it ran? Also I forget which engines have it but could it be a crank angle sensor?
Old Jan 30, 2003 | 09:36 AM
zexteg's Avatar
Default Re: code 71,72,73,74 (LS-hatch)
yea it threw the codes before and after the change, no improvment on how it ran either
Old Jan 30, 2003 | 09:45 AM
sgT's Avatar
sgT
did you do anything to the car before it started running like crap?
Old Jan 30, 2003 | 12:49 PM
1SlowB16EF's Avatar
were the old plugs fouled? sounds like a possible map sensor problem
Old Jan 30, 2003 | 01:55 PM
zexteg's Avatar
Default Re: code 71,72,73,74 (1SlowB16EF)
well thanks neways fellas but looks way worst i tried everything and well ran a compression test again and sure enuff no3. cyl valve retainers let go so the teggy is now sleepin and on hold for the turbo operation
Thanks alot guys
Gary
Old Jan 30, 2003 | 02:08 PM
TheHater
Guest
Posts: n/a
Same thing started happening to me before my Motor blew up. What were your mods? And what type of car do you have?
B18C-Hatch-Turbo
Apr 3, 2014 03:03 PM
boostedr
Feb 26, 2009 07:13 AM
stocker2shocker91
Jan 9, 2007 01:04 PM
4inspeed
14
Oct 13, 2003 06:24 PM
sagaprelude
Dec 20, 2001 09:12 AM
