Possible TPS and MAP sensor Code causes??
Old Mar 15, 2014 | 10:17 AM
B18C-Hatch-Turbo's Avatar
Default Possible TPS and MAP sensor Code causes??
I have a JDM B18C and it throws a MAP and TPS sensor code intermittently; I have checked the MAP and TPS sensors and harnesses and they are good (followed this link)
http://troubleshootmyvehicle.com/hon...e-map-sensor-3
The codes always come on together; never 1 then the other and there doesn't seem to be a pattern (i have checked the wiring and sensors with and without the code)
I have cleaned the TB; IACV (hi and low speed) replaced the o-rings, new plugs and wires and followed this diagnostic: https://honda-tech.com/forums/honda-prelude-4/end-all-idle-surge-bounce-etc-problems-thread-1979500/
Is there anything else that could cause this? I am at a complete loss
Old Mar 15, 2014 | 01:41 PM
Default Re: Possible TPS and MAP sensor Code causes??
the car was sitting for almost a year; could the gas have gone bad and cause this?
Old Mar 16, 2014 | 11:56 AM
112 views and nothing???
So just checked the grounding - all good
did a valve adjustment - couple exhaust valves were out .001" and all within spec now
Timing belt is on correct teeth
did a compression test 195, 200, 205, 210 psi (JDM @ 10.6 compression ratio)
any suggestions on what do look for next? Can i even check ignition timing with a CEL
Old Mar 17, 2014 | 03:46 PM
just doubled checked for air in coolant - nada
bump
Old Mar 17, 2014 | 05:02 PM
SolScifen's Avatar
are the plugs on the sensors loose? maybe a bad connection?
does it actually run bad, or just throw the codes?
Old Mar 17, 2014 | 07:29 PM
fcm's Avatar
fcm
Old Fart
Same question, "does it actually run bad, or just throw the codes"?
I also agree, because it is intermittent, I would make sure terminals are tight, best way is to depin the female terminal, inspect it for corrosion and carefully "tighten" the pin up, re-pin and see what happens. 94
Old Mar 18, 2014 | 01:01 PM
it runs bad when the codes are one; lumpy as if it's missing - and removing the connectors doesn't change how it runs at all
I double checked the senors/connectors/wiring and all good but this time i was able to get it to temp without a code. I checked the ignition timing and it's perfectly on 16 deg.
Old Mar 18, 2014 | 01:05 PM
B_Swapped93's Avatar
can you try a new map and tps they're like 5$ for both at junk yards around here D-series ones will work btw.
Old Mar 18, 2014 | 03:49 PM
i'll try look for a new sensors but still don't think they are the root cause.
I took it for a drive and noticed that my brakes are not engaging until 1-2" from the floor; pedal isn't spongy and the pedal does return to starting position. I can pump the pedal which causes engine to rev but during the drive after a hard stop the car just died as i pull off. I turned the car off and waited a little it started up and ran with out any codes...could this have something to do with it?
Old Mar 18, 2014 | 07:03 PM
Garage_Spec's Avatar
In for the same issue only mines just throwing low tps voltage, unplug map and engine runs smooth. Have also checked about every possibility.
Old Mar 19, 2014 | 05:05 PM
so MAP and TPS let the ECU know about the mass flow and it adjusts the timing so maybe it's throwing these codes because of incomplete combustion...my thinking is the ECU is blaming the sensors but this could be do to the distributor or fuel injectors going bad???
today I started the car and no problems; run up to temperature with very little idle fluctuation - no codes
Old Mar 20, 2014 | 04:06 PM
poured a bottle of seafoam in the tank...cranked and ran perfectly - brake feels better everything ran smooth like it should. Thinking now may have just been carbon buildup/dirty injectors?
highly recommend seafoam; going to do the intake manifold this weekend. Might help you https://honda-tech.com/forums/members/garage_spec-999877053/
Old Mar 22, 2014 | 12:26 PM
I have replaced my injectors but they were used, maybe I should try that. My car runs decent but after 60 seconds it just dies. Possibly clogged filter or just dirty injectors?
Old Mar 22, 2014 | 12:52 PM
INB4 rod knock from too much seafoam....
Old Mar 24, 2014 | 07:33 AM
tech@Eagle's Avatar
If memory serves me correct, Aren't the TPS and MAP plugs the same (plug configuration)? Is it possible you have them swapped? (i.e. the TPS plug plugged into the MAP and vise-versa).
Old Mar 24, 2014 | 11:07 AM
I still have not found a solution, yes they are the same but I labeled them before removing, plus the tps wires are not long enough to stretch to the map without it being obvious that it's switched. I have gone as far as checking ecu pins and even testing a separate ground. Nothing has worked so far, engine dies under a load even with map unplugged
Old Mar 24, 2014 | 11:29 AM
HondaPartsHero's Avatar
Technical Hero
Garage Spec it might help to start your own thread just because your setup, car, engine etc might be different from the original. Do that and add all the details.
Old Mar 24, 2014 | 03:25 PM
i just installed a new fuel rail and my injectors were really filthy; so i clean them and what little i could reach in the intake manifold (Edlebrock Victor x) and car has been running really well lately - I think it's got to do with combustion since they always come on together.
Old Mar 30, 2014 | 08:58 AM
codes are back...doubled checked the input voltage and low and behold my ECU is putting out 3.7volts now (pin to chasis ground)
Any idea on what could be the casue of that? Is thinking the voltage regulator could be the cause wishful thinking and likely just have to get a whole new ECU?
Old Apr 3, 2014 | 03:03 PM
So I was checking the power to the TPS signal and it was 3.7V however when i removed the MAP sensor it jumps to 4.7V - Think this points to a harness/short/ground issue?
Anyone know if the MAP and TPS share a ground?
eggie75
Apr 7, 2008 01:40 PM
FSS13foxtrot
Jan 20, 2008 06:23 AM
92ehatch
16
Feb 19, 2007 11:41 PM
JibOnALib
12
Sep 14, 2005 11:51 AM
dan89crxsi
Mar 1, 2004 03:03 PM
