my car dead??? damn!!!
Old Dec 18, 2001 | 11:56 PM
sagaprelude's Avatar
Default my car dead??? damn!!!
ok, i was almost home, like half a mile away, then i get a CEL...then all of a sudden my car starts trippin...starts to slow down like crazy, boggs like a madman and backfires nonstop!! and i had to ride the clutch all the way home drivin like 5mph!! whats happening?!?!? i thinkin a blown head?!?!
Old Dec 19, 2001 | 12:02 AM
LsTurbo91's Avatar
Default Re: my car dead??? damn!!! (sagaprelude)
inspect your distributor, rotor, cap, plugs.
Old Dec 19, 2001 | 12:04 AM
VaporTrail's Avatar
New User
whats the code? Check your code, and your plugs. Replace plugs, reset ECU. If the problem is still there, inspect your MAP sensor, plug wires, and do a compression test.
Old Dec 19, 2001 | 07:04 AM
Default Re: my car dead??? damn!!! (VaporTrail)
i got codes 72,74 and 3
Old Dec 19, 2001 | 07:05 AM
SiR Kid's Avatar
New User
Check the rotor.... mine came loose and broke off the distributor... sucked hard til I found out it was a $6 fix...
Old Dec 19, 2001 | 07:27 AM
BuCU's Avatar
Default Re: my car dead??? damn!!! (SiR Kid)
Code # 3 = MAP Sensor
Code #72 = Cyclinder #2 Misfire
Code #74 = Cyclinder #4 Misfire
Looks like your MAP sensor is either defective or your check valves are not functioning correctly and thus causing the 2 cyclinders to MISFIRE. Take your plugs out and check them for detonation. Seems to me that the MAP sensor has gone bad or the check valves are not doing the job.
Update us if you would please...
David
Old Dec 19, 2001 | 08:14 AM
Default Re: my car dead??? damn!!! (TeamElusive)
ok, i reset my ecu, had to get my car runnin..had a final today, i will check everything when i get home from work.....hopefully everything is ok..ill keep everyone posted
Old Dec 20, 2001 | 09:12 AM
93B17A's Avatar
yeah i had my my rotor fall off too i thought i blew the motor
toolbox21
May 8, 2010 09:17 AM
boostedr
Feb 26, 2009 07:13 AM
eggie75
Apr 7, 2008 01:40 PM
kaj
Sep 27, 2003 09:36 AM
Frosty_spl
Feb 12, 2002 02:06 PM
