Crank pulley
Old Jan 28, 2003 | 02:12 PM
Eluder200K's Avatar
Default Crank pulley
Ok the crank pulley bolt is lefty loosey correct? even thought the motor turns counterclockwise? I'm having trouble getting it off.
this is on an 89 prelude but I believe the ITR is the same.
Old Jan 28, 2003 | 03:17 PM
Padawan's Avatar
Darth ModerVader
Default Re: Crank pulley (Eluder200K)
The only thing that worked for me was a lot of air and a 3/4" impact gun that weighs around 15 lbs.
Old Jan 28, 2003 | 04:14 PM
Eluder200K's Avatar
Default Re: Crank pulley (Padawan)
I have a gun and just wanted to make sure I am going the right direction even though I am 99% sure. The compressor I have just isn't putting out enough air so I will have to put the whole car back together and take it to a garage so they can break this thing loose. Dam it, just when I thought it was going to be easy to replace the Timing belt...
Now it does loosen going counter clockwise right?
Old Jan 28, 2003 | 04:26 PM
Buckshot's Avatar
im pretty sure it goes left...and chances are you are going to need more then a impact gun, unless yours has some *****
i had to use like a 3 ft long breaker bar, put it in 5th gear and mash on the brakes..it was a bitch
Old Jan 28, 2003 | 04:30 PM
Eluder200K's Avatar
Default Re: Crank pulley (Buckshot)
aaahhhh, did you use an extention that was like a ft and a half long then to reach outside the fender?
I think i'll try that...
Old Jan 28, 2003 | 04:33 PM
Philly_NBP_R's Avatar
still struggling with this???
Old Jan 28, 2003 | 04:45 PM
Turtle's Avatar
Default Re: Crank pulley (Philly_NBP_R)
Well when changing out my cam gears I had to turn the crank counter-clockwise to tighten the belt (if memory serves me correctly). If this IS true, then that would suggest that the bolt is reverse threaded...but someone who knows for sure will answer...cause I could be wrong...don't have helms in front of me.
B
Old Jan 28, 2003 | 06:43 PM
Padawan's Avatar
Darth ModerVader
Default Re: Crank pulley (Turtle)
It's regular, not reverse thread.
Old Jan 28, 2003 | 06:49 PM
Turtle's Avatar
Hey like I said...I wasn't 100% sure on that . Thanks for correcting me...
Old Jan 28, 2003 | 06:57 PM
JDM CTR '00's Avatar
Old Jan 28, 2003 | 10:49 PM
Eluder200K's Avatar
Default Re: Crank pulley (ChargedSi99)
oh, excellent. Thanks alot guys, the saved-my-*** meter just went up yet another notch
BLKFLSH
Apr 10, 2011 01:54 PM
B!^A@
Nov 21, 2006 10:04 AM
djnikko
19
Apr 24, 2005 07:43 PM
93gsrcoupe
Sep 30, 2004 09:54 PM
LudeHatchH22a
Feb 25, 2004 08:57 PM
