Stop Tein SS from rusting!
Clean and then soak them in WD-40 monthly.
ttt! any other coil over out there for this price? I will be using for the street like 99 percent of the time..and if I am lucky..i will get on a road corse..
its a shame that a company like tein wouldnt resolve their rusting and seizing issues... its not like they're cheap
I was curious also because I"m about to purchase some SS within the month. But if you guys said they are teflon coated it should be ok, hopefully.
I heard teflon tape is bad..If moisture got under it... ya..
Anti rust spray, great idea!, thanks
You can add that in the box with the other thing
Um get new springs. Go to youre nearest circle track and get springs, You need Stiffer ones anyway. New springs will cost $50each.
someone mentioned lithium grease before, i dont know what that is, but its supposed to work.
Also, the higher end Teins come with a tube of special grease that is supposed to prevent rust. I could be wrong.
