Stop Tein SS from rusting!
Old Jan 27, 2003 | 06:16 PM
ragejed's Avatar
Default Stop Tein SS from rusting!
How would I go about stopping the tein SS threads from rusting...I thought about spraying them with teflon? or some kinda spray clear sealant...ideas?
Old Jan 27, 2003 | 06:45 PM
JohnnyK's Avatar
Default Re: Stop Tein SS from rusting! (ragejed)
Clean and then soak them in WD-40 monthly.
Old Jan 27, 2003 | 07:05 PM
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
Default Re: Stop Tein SS from rusting! (JohnnyK)
Why dont you email Tein? I want to know also.
Old Jan 27, 2003 | 08:04 PM
ragejed's Avatar
Default Re: Stop Tein SS from rusting! (FrostyDC4)
Hoping someone would have a good idea here.
Old Jan 27, 2003 | 10:17 PM
Windows 95's Avatar
Doesn't sound too painful.. or how about just wrapping the threads and coils in like a clear seran wrap? Sounds kind of ghetto, but it should keep out most water and save your teins.. you might encounter moisture probs still though, so spraying the threads w/ WD once a month and cleaning them doesnt sound like a bad idea..
Old Mar 12, 2003 | 11:52 AM
ragejed's Avatar
Default Re: Stop Tein SS from rusting! (Windows 95)
ttt! any other coil over out there for this price? I will be using for the street like 99 percent of the time..and if I am lucky..i will get on a road corse..
Old Mar 12, 2003 | 12:03 PM
Kelvin96GSR's Avatar
25 Year Member
I thought putting anti sieze on the them would stop them from rusting?
Old Mar 12, 2003 | 12:26 PM
ragejed's Avatar
Default Re: Stop Tein SS from rusting! (Kelvin96GSR)
prolly.. Also Silicone lubricant..the spray can says it sticks to metal
Old Mar 12, 2003 | 12:42 PM
ajchen's Avatar
its a shame that a company like tein wouldnt resolve their rusting and seizing issues... its not like they're cheap
Old Mar 12, 2003 | 01:01 PM
emr88's Avatar
Default Re: Stop Tein SS from rusting! (ajchen)
I thought I read somewhere that the newer Tein's are teflon coated because of this known problem. Call up Tein maybe they can do something for you.
Old Mar 12, 2003 | 02:23 PM
integobsession's Avatar
Default Re: Stop Tein SS from rusting! (emr88)
I'm interested to know also... I may be purchasing these in the near future...
Old Mar 12, 2003 | 02:52 PM
MikeyDB7's Avatar
the flex series and above is teflon coated...any model under that, SS, basic, is not teflon coated
Old Mar 12, 2003 | 03:18 PM
tC_Dragon's Avatar
Default Re: Stop Tein SS from rusting! (MikeyDB7)
good to kno...
Old Mar 12, 2003 | 04:40 PM
goforbroke's Avatar
MEAT PATTY
Default Re: Stop Tein SS from rusting! (pdcdragon)
I was curious also because I"m about to purchase some SS within the month. But if you guys said they are teflon coated it should be ok, hopefully.
Old Mar 12, 2003 | 05:02 PM
XDEep's Avatar
Default Re: Stop Tein SS from rusting! (goforbroke)
jic's are stainless steel i believe
Old Mar 12, 2003 | 06:09 PM
ragejed's Avatar
Default Re: Stop Tein SS from rusting! (XDEep)
Why not just put anti seize (sp?) crap on them?
Old Mar 13, 2003 | 12:24 PM
Xscream's Avatar
I second the anti sieze
Old Mar 13, 2003 | 12:31 PM
Rory Breaker's Avatar
You should be able to get rust prevent spray at any hardware store. Antisieze, teflon tape, etc...that should all be fine.
Old Mar 13, 2003 | 01:00 PM
ragejed's Avatar
Default Re: Stop Tein SS from rusting! (newgsrdriver)
I heard teflon tape is bad..If moisture got under it... ya..
Anti rust spray, great idea!, thanks
You can add that in the box with the other thing
Old Mar 13, 2003 | 08:56 PM
vtecsdn's Avatar
I coated mine with water resistant snowmobile grease from Napa. Seems to be a good protective coating.
Old Mar 13, 2003 | 10:56 PM
deepgreengsr's Avatar
Default Re: Stop Tein SS from rusting! (vtecsdn)
Um get new springs. Go to youre nearest circle track and get springs, You need Stiffer ones anyway. New springs will cost $50each.
Old Mar 14, 2003 | 03:12 AM
ragejed's Avatar
Default Re: Stop Tein SS from rusting! (deepgreengsr)
WTF are you talking about?
Old Mar 15, 2003 | 10:45 AM
Audio28's Avatar
wtf tein's rust!!
Old Mar 15, 2003 | 09:04 PM
Rtzx9r's Avatar
GDD 1%
Default Re: Stop Tein SS from rusting! (Audio28)
GRACE!!! err I mean Grease.... Too much Ferris Bueller's Day Off.
Old Mar 16, 2003 | 01:12 AM
EF-9SiR's Avatar
Default Re: Stop Tein SS from rusting! (Rtzx9r)
someone mentioned lithium grease before, i dont know what that is, but its supposed to work.
Also, the higher end Teins come with a tube of special grease that is supposed to prevent rust. I could be wrong.
Trilladelphia
Jun 7, 2014 02:59 AM
radeon
Suspension & Brakes
Feb 1, 2010 11:33 AM
lDanny
May 6, 2004 05:05 PM
ITR_1211
Dec 25, 2003 09:11 PM
dre000
May 13, 2003 09:04 AM
