Todays JDM Type R compression test.
2000 JDM Type R
I tested it in class today, and here are the results:
185, 185, 187, 185
Good? Sound about right for a stock engine?
I'm happy now, knowing I have a good engine from over seas.
185, 185, 187, 185
The numbers are really close together which from wat I read is the most important thing. They do seem a bit low though as the JDM Type R engine I believe has 11:1 compression with our 10.6:1. When I tested the compression in my 98 back in February I believe the numbers were in the 220's. Did you do the test with the throttle all the way open? Anyway I wouldn't worry about it and be happy that the numbers are so close
[Modified by HondaRcB, 8:47 PM 1/27/2003]
No, I never touched it.
I'll do it again tomarrow..
How is the compression test results affected on a cold motor vs warm?
It should be warm correct?
I know the most important thing is to not have each cylinder vary. But why do some motors have low numbers, and others have higher numbers, but both motors will put out good numbers on a dyno and pull hard?
Is there any way to calculate the compression ratio using a cylinders psi?
It should be at operating temp when doing it..
I can't believe I forgot this today, I was in a big hurry I guess....
jmeyer99
Oct 4, 2010 03:30 PM
