Why am I having so much trouble with coils and icms?
Do I just have bad luck? Just recently, at a track, revving my car caused a slight hesitation. Then on the way home, as soon as the tach would hit approx. 3600rpm...it'd fluctuate back and forth. I'm guessing the ignitor or coil is going bad.....again!
It seems like I've gone through too many coils/ignitors/dist.housings over only maybe an 8 month period.
Is this a common problem with b series motors? What can I do? Some buddies say upgrade to an msd ignition w/ external coil (not to mention the coils are cheaper). But even so...my motor is virtually stock (i/h)...I should not be killin coils/ignitors so easily.
This is a gsr motor. I hope it's OK that I'm posting in the type R forum...but it seems like you get a lot more/better responses here.
Thanks guys,
Rod
Thanks guys,
Rod
HYPROPULSION_R
Jan 11, 2008 01:04 PM
messeduprex
May 15, 2006 03:12 PM
gsrvx
Jan 27, 2003 03:19 PM
