When installing 3 bar map (already searched, not a wiring question)
Old Jan 26, 2003 | 06:51 AM
Smashback's Avatar
Default When installing 3 bar map (already searched, not a wiring question)
Do you guys leave the stock map sensor on the tb and just tap into vaccuum somewhere else?
I think somebody needs to have some flanges made that will bolt up in place of the stock map and give you a nipple so you can hook up the 3 bar
Old Jan 26, 2003 | 07:02 AM
boostaholic's Avatar
Default Re: When installing 3 bar map (Hatchblack)
The stock map sensor makes for a good plug so i just left it there and just drilled and tapped another barb fitting for the 3 bar map.
Old Jan 26, 2003 | 07:22 AM
Farnsrocket's Avatar
Default Re: When installing 3 bar map (boostaholic)
During my install, I quickly (the key word here being quickly) fabbed a plate that I cut out from some aluminum, drilled some screw holes and mounted it. The oring under the stock MAP sensor seals it. Then I connected the GM MAP to a nipple on my manifold. If I ever get around to it, I thought of connecting a barb to this plate, either JB Weld style or maybe make a new plate with thicker aluminum or steel and thread it on. It probably wouldn't make any difference, vacuum is vacuum, but it would look neat.
Old Jan 26, 2003 | 08:07 AM
ekb18c's Avatar
leave the stock map in there(TB) and then tap your intake manifold for another vac source.
Old Jan 26, 2003 | 08:25 AM
Smashback's Avatar
Default Re: When installing 3 bar map (ekb18c)
Problem is that after a certain PSI won't the stock one be damaged and then no useless if you ever need it again?
Old Jan 26, 2003 | 10:18 AM
That's a good question.......does the map sensor just not register the higher psi or does it actually break?
Old Jan 26, 2003 | 12:24 PM
Doodoo's Avatar
Default Re: When installing 3 bar map (Farnsrocket)
I made a block off plate similar to Farnsrocket's. Mine has a nipple connected to it. I used my Missing link as a template.
Old Jan 26, 2003 | 12:59 PM
QCKGSR's Avatar
Default Re: When installing 3 bar map (Doodoo)
Just make a plate for the hole you created and make sure the 3-bar has its own dedicated source!
Old Jan 26, 2003 | 01:14 PM
Default Re: When installing 3 bar map (QCKGSR)
hey Doodoo, how did you connect the nipple to the plate??
Old Jan 26, 2003 | 06:45 PM
Smashback's Avatar
Here's how I did it about an hour ago
Old Jan 26, 2003 | 08:16 PM
Joseph Davis's Avatar
It does the first until it does the second.
I think Speed PHreak has popped a stock MAP in the 8-10psi range. They read boost and all, but it's pretty near the limit of their diaphragm's travel and they don't last as long due to the stress... lasts a fairly long time, but it's not 100% reliable like stock.
Old Jan 26, 2003 | 08:24 PM
TREVER's Avatar
Default Re: When installing 3 bar map (J. Davis)
I ruined a map by purging my nos. I think I over pressurized the manifold.
I would remove the stock map. Then fab your own block off/nipple set up.
Old Jan 26, 2003 | 08:32 PM
1.8T_EG's Avatar
Default Re: When installing 3 bar map (TREVER)
... great info!!!... i wish i was boosting that hard...
Old Jan 27, 2003 | 03:33 AM
Default Re: When installing 3 bar map (1.8T_EG)
Looks good Hatchblack!
ekk41
Oct 24, 2007 05:28 PM
KRWTEK1
May 28, 2007 12:32 AM
sleeprhatch
Sep 23, 2006 12:04 PM
SpoolnByYou
Dec 29, 2005 10:00 AM
PrecisionPerformanceParts
Apr 17, 2002 07:53 PM
