Part # for GM 3 bar map sensor
Old Apr 17, 2002 | 01:40 PM
PrecisionPerformanceParts's Avatar
Default Part # for GM 3 bar map sensor
Just as the title states, I need the part # for the correct GM 3 bar map sensor.
Thanks
Old Apr 17, 2002 | 01:41 PM
TurboR's Avatar
New User
Default Re: Part # for GM 3 bar map sensor (fatkid)
How much do they usually cost?
Old Apr 17, 2002 | 01:46 PM
Default Re: Part # for GM 3 bar map sensor (TurboR)
From my understanding, $50-$60
Old Apr 17, 2002 | 01:56 PM
TurboTegB18c's Avatar
The correct part # is 16040749 The retail on these from the dealer is around $90. Hope that helps
Old Apr 17, 2002 | 02:14 PM
Default Re: Part # for GM 3 bar map sensor (TurboD16Z6)
Thanks for your help, thats what I thought, but wanted to confirm with someone.
At gmpartsdirect.com its 49.95 plus shipping
Old Apr 17, 2002 | 03:51 PM
Spocko's Avatar
I still am a little confused on how to hook that up to a Honda. I know that they said only one MAP sensor can be connected at a time, but what do you do- remove the old map sensor from the TB/IM and try to install the GM in it's place(doesn't seem like it could fit there)? Or something else?
Any help would be appreciated!
Old Apr 17, 2002 | 05:27 PM
Default Re: Part # for GM 3 bar map sensor (Spocko)
You have 2 choices, either tap in the throttle body where the old map use to be with a fitting and route it out to your 3bar map, or you can just leave your old map screwed in but disconnected and rounte a vaccum to the 3bar. Hope that helps
Old Apr 17, 2002 | 06:29 PM
Anubyss's Avatar
Just curious. Why do you guys favor the GM 3 bar model instead of the MSD 3 bar unit? Is it better, or just proven? I know they both cost the same.
Old Apr 17, 2002 | 06:31 PM
SEFIxCivic's Avatar
Default Re: (Anubyss)
the MSD is a GM sold under the MSD name from my understanding.
Old Apr 17, 2002 | 07:53 PM
Default Re: (SEFI8LOxCivic)
3bar map is a 3bar map, same ****.
turbolshatch
Feb 2, 2006 06:06 AM
TurboGS-R
Aug 18, 2005 01:28 PM
CiViC SiR
Jul 7, 2003 02:55 PM
