Typical Retail Short Shifter Lengths?
Old Jan 25, 2003 | 07:05 PM
ScottEK's Avatar
Default Typical Retail Short Shifter Lengths?
I'm cutting my shifter tomorrow, I was just wondering if anyone knew some typical lengths of retail short shifters. I dont want to go too far or not far enough...
Old Jan 26, 2003 | 02:51 PM
CRXSi90's Avatar
Default Re: Typical Retail Short Shifter Lengths? (beta13)
ok, this is a good and interesting question. I would like to know the answer also. I've seen some pictures comparing stock shifters and short ones. I don't know where they are, though.
Old Jan 26, 2003 | 08:52 PM
ScottEK's Avatar
Default Re: Typical Retail Short Shifter Lengths? (CRXSi90)
I talked to a Skunk2 distributor today and he said the ones he sells are 12" long.
Old Jan 27, 2003 | 02:20 PM
CRXSi90's Avatar
PACESETTER ADJ.
Get flick-of-the-wrist shifting with Pace Setter's Quick-Shift Adjustable Throw Shifter. By allowing you to adjust stick height and shorten shift throws by up to 80 percent, These Quick-Shifts offer faster, more precise shifting. These one piece polished and chrome plated shifters are formed from an extremely durable steel alloy and use Pace Setter's exclusive AdjustaBall shift ball, which features low friction and extreme long life characteristics.
And while looking at my summit racing catalog, it says neuspeed reduces shift throw by 30-50%
so there you have it...just make the lower part that much longer (so you have leverage and more movement) by a percent within those ranges (I probably wouldn't do the 80%....I'd stay within the 30-50% or less) and you'll have yourself a short shifter. I hope that makes sense...
incase it doesn't.....here is an example procedure...
measure from the center of the ball to the center of the pivot. Multiply this number by 1.x to get the new "short shifter" legnth. (1.3 for 30% shorter...1.5 for 50% shorter)....this will only be the case if you only add to the bottom but don't add to the top. It gets even shorter if you cut from the top, but isn't the same. Ok, that just got way too confusing.
Well, I think you can figure it out, but keep in mind that the bottom supposedly can hit the exhaust if it is "shortened" too much....I'd take some measurements if I were you.
Tell us how it goes.....I know it is past your scheduled date for this project.
Han Solo
Jan 8, 2007 01:01 PM
EJ8 GSR-T
Dec 13, 2006 10:20 AM
JDean6pac
Feb 21, 2006 10:38 AM
lacking vtec
Feb 11, 2006 07:36 AM
ramz7887
May 16, 2003 12:34 PM
