how do i get the bolt out from my exhaust housing???
i got all bolts out but this one and the another one that's stuck like this one. For some reason the housing doesn't rotate! i thought it's supposed to rotate??
[Modified by accordfreak, 1:58 AM 1/25/2003]
did you try pushing harder?? you know put your back into it. i kown i had to tighten one bolt and then rotate mine when i put it on because i coudnt tighten it when it was on.
what happens is rust "welds" the cartridge and exhaust housing togeather, you may try heating it up to 350 degrees, and then tapping the housing to break the rust loose, the housing does turn and will turn, it just takes some work.
Brad
Brad
yeah try a little harder, get some anti corrosive stuff in there.
[Modified by PreIudeSI, 3:59 AM 1/25/2003]
BodyKits NW
Mar 10, 2006 02:38 PM
BlueSi2k
Mar 31, 2004 01:56 PM
