possible to mig weld stainless steel?
Old Jan 23, 2003 | 09:48 PM
project dc2's Avatar
Default possible to mig weld stainless steel?
i just purchased soem 304L stainless steel bends in hopes of welding up a log sytle manifold for my integ .. but im reading here and there that i cant use a mig welder on stainless steel ?? **** .. im gettin majorly irritated here .. can someone help me answer this question of mine >????
Old Jan 23, 2003 | 09:53 PM
BudaKai's Avatar
Default Re: possible to mig weld stainless steel? (project dc2)
Depends on the welder and the fillers used.
Old Jan 23, 2003 | 09:54 PM
Default Re: possible to mig weld stainless steel? (tzsir)
hrmm just regular fillers that are used to weld mild steel ? i dont need this **** to be rust free or anything .. i just thought it woudl be stronger to use stainless steel .... now im kinda kickin myself in the *** cuz it seems like you cant do it ..
gases and fillersa regular muffler shop woudl have
[Modified by project dc2, 7:00 AM 1/24/2003]
Old Jan 23, 2003 | 10:06 PM
lazerus's Avatar
Try it with your setup and see if you can get it to work. you can weld stainless to mild. but it's just not quite as strong. Read: Should be fine for an exhaust system
Old Jan 23, 2003 | 11:39 PM
hpfsi's Avatar
Yes you can mig weld stainless - you just need the proper shielding gas and stainless wire. Talk to your local welding supply store. MIG welds are plenty strong (and can be almost if not as strong as a TIG weld), but one of the main disadvantages is that you can't weld in tight spots very easily due to the size of the nozzle tip. With a log style manifold you should be alright though.
Old Jan 23, 2003 | 11:42 PM
dustin's Avatar
Default Re: possible to mig weld stainless steel? (hpfsi)
You can definately mig weld stainless steel.
The hardest part about stainless is that you really need to back purge it because it crystalizes on the back side of the weld when exposed to oxygen (forms black metallic crystal junk). You can use solar flux, but back purging is going to work better.
You can buy solar flux from http://www.burnsstainless.com/Hardwa...vicecosts.html
Old Jan 23, 2003 | 11:47 PM
dustin's Avatar
I've yet to see a muffler shop that routinely works with stainless.
The advantage to using stainless steel is definately not in the strength area -- It's in the durability and resistance to corrosion/rust area. It also offers bling factor when polished.
Old Jan 24, 2003 | 01:09 AM
frogscivic's Avatar
just like it has been said you can weld stainless with a mig you just need to have stainless wire in the welder gun. If you have access to a tig welder I would recomend you tig it. Much stronger, cleaner, looks a hell of alot better. Idealistically anything you weld should look like a roll of coins.
Old Jan 24, 2003 | 04:02 AM
Phoenix GSR's Avatar
Default Re: possible to mig weld stainless steel? (frogscivic)
most the diy people in here cant afford a $1200+ tig welder...
stainless work fine on a mig..
if you bought your bends from McMaster-Carr they will definately not be stronger.. their stainless butt weld pipes are schedule 10, the mild steel ones are schedule 40 (a lot thicker) so I am guessing the mild steel ones would be stronger, but stainless should look better once polished
Old Jan 24, 2003 | 08:03 AM
paulzy's Avatar
Default Re: possible to mig weld stainless steel? (Phoenix GSR)
Who ever sad that TIG is stronger than MIG? That's not true. Mig is just as good as the Tig.
if you wanna weld 304 stainless with the MIg, you'll need to go to the wleding supply store and pick up some 308 or 309 stainless wire for your machine
Old Jan 24, 2003 | 08:39 AM
dustin's Avatar
Default Re: possible to mig weld stainless steel? (1320development)
I think it's easier to make stronger welds with TIG. MIG can look great but have zero penetration -- but with TIG you usually know whether you have enough penetration.
Old Jan 24, 2003 | 09:24 AM
Smashback's Avatar
Default Re: possible to mig weld stainless steel? (dustin)
Just a note, when I had my exhaust done the stainless muffler was welded to mild steel piping using the same wire and gas the guy uses (mild wire and 75/25 gas) on mild to mild welds with no problems.
Old Jan 24, 2003 | 09:38 AM
dustin's Avatar
Default Re: possible to mig weld stainless steel? (Hatchblack)
Stainless should be welded to mild with 308 or 309 wire/rod. 309 is better, it's designed to join somewhat dissimilar metals.
Old Jan 24, 2003 | 11:29 AM
i called up a muffler shop today and ask if they coudl do it. most of them said they could. i asked what wire one of the shops used he said he uses a combination wire ?? that has stainless and mild in it or somethgin so they can weld all sorts of metals ... is this legit or is he just pullin my chain ?
Old Jan 24, 2003 | 11:52 AM
dustin's Avatar
He's probably talking about 309 but it doesn't have 'mild in it'.
Old Jan 24, 2003 | 12:15 PM
mos's Avatar
mos
They have schedule 40 in stainless also. 316 or 304.
Old Jan 24, 2003 | 02:37 PM
Default Re: possible to mig weld stainless steel? (mos)
does anyone know how thick the schedule 10 is?
Old Jan 25, 2003 | 12:24 AM
The Mick's Avatar
It varies depending on the size of pipe you're dealing with. Check this site for a nice calculator.
http://www.onlinemetals.com/pipe.cfm
f20cmx5
Welding / Fabrication
10
Oct 3, 2011 04:49 PM
Rodney
20
Dec 9, 2008 04:08 PM
sleepystyle
Apr 1, 2006 09:24 PM
Pat
Apr 5, 2003 07:24 PM
project dc2
Jan 24, 2003 08:14 AM
