weld titanium to stainless?
Old Dec 7, 2008 | 02:13 PM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
Default weld titanium to stainless?
is it possible to weld ti to stainless? complicating it further, can it be done with a mig? it doesn't need to be pretty, just functional. this is for a quick release exhaust setup. thanks.
Old Dec 7, 2008 | 03:47 PM
MilwaukeeMotorwerks's Avatar
Im going to say No either way. Two completely different metals.
Old Dec 7, 2008 | 03:53 PM
Rodney's Avatar
i have mig'd my stainless exhausts, i have not had the hcnace to try a bead on the ti tubing yet. perhaps i can lay a bead, but it won't last?
Old Dec 7, 2008 | 04:16 PM
Flashmn's Avatar
stainless and mild still have iron component, stainless just has chromium that makes a layer that inhibits rust. If you weld it with mild steel wire, it turns to mild steel at the weld.
If you weld with stainless wire and CO2 you end up having a really crappy looking bead, becuase stainless takes carbon from the gas.
As for titanium and stainless, definately it wont work, besides you need a room filled with argon when you weld titanium or a closet where you put the titanium pieces and weld them in the closet.
Old Dec 7, 2008 | 04:42 PM
k24em2's Avatar
http://www.welding-advisers.com/PRAC...etterNo33.html
Theres some reading. Quick answer is no. Longer answer is yes, but you will not have the ability or resources to do it.
Old Dec 7, 2008 | 04:47 PM
weiRtech's Avatar
OG Fabricator
not so.
if you have a trailing shield setup, it isn't necassary to have an argon cabinet. how do you think larger ti pipes are welded on site?
Old Dec 7, 2008 | 06:12 PM
Nick Z32's Avatar
yea Ti welds at 800 degrees and SS is around 1150
the two metals are completely different even tho they have excellent corrosion resistance characteristics
but there are ways of joining the two...
Old Dec 7, 2008 | 06:26 PM
essex's Avatar
Do you have a new exciting car? I thought the civic was for sale
Old Dec 7, 2008 | 10:38 PM
Mr.Burner's Avatar
i have repaird a titanium exhaust without using a booth and it works fine...and welding the two together is possible...
its like welding thick stainless to thin......obviously the thin melts sooner. as for welding the ti to stainless, the ti will melt sooner.
Old Dec 7, 2008 | 11:26 PM
d16sandrail's Avatar
All you guys are WAY over thinking this one! you can bet the farm my good buddy JB can stick the two pieces together, if by some chance he can't than I know my other buddy Duct can get it done ;-)
Old Dec 8, 2008 | 12:23 AM
NTCustoms's Avatar
there are simpler ways to join the 2. why don't you just use a v-band?
Old Dec 8, 2008 | 12:53 AM
Nick Z32's Avatar
because there are no Ti vbands....
Old Dec 8, 2008 | 03:30 AM
Rodney's Avatar
this is the exact route i was going. i guess i will have to find a different front section, but after i butcher the exhaust trying....
Old Dec 8, 2008 | 04:03 AM
ATYPR's Avatar
http://www.highenergymetals.com/
Old Dec 8, 2008 | 04:13 AM
ROTARY's Avatar
you could also just slip-fit the exhaust side tube and clamp it.
Old Dec 8, 2008 | 04:22 AM
mar778c's Avatar
Community Builder
Community Influencer
Originally Posted by ATYPR
You beat me to it. The only commerical methods I know off for bonding titanium to steel would be an inertia method.
Old Dec 8, 2008 | 09:14 AM
NTCustoms's Avatar
slip fit would seem like it would work
Old Dec 8, 2008 | 11:59 AM
Rodney's Avatar
it would seem that way, eh? nah. too much work to repeatedly do this. and the ti fatigues, that is why i have the exhaust, because it is cracked in a few spots. no big deal, i will just use a SS front section.
Old Dec 8, 2008 | 05:34 PM
damnraz's Avatar
I use 4951 ti wire and weld it onto stainless bends if one of my mandrel ***** are broken and stuck in there. Tap it with a hammer and it cracks it open!
Old Dec 9, 2008 | 05:30 AM
turboteener's Avatar
Banned
Friction weld or explosive weld would probably get the job done, but you can't so either so your best bet is some form of mechanical connection.
Old Dec 9, 2008 | 04:08 PM
Nick Z32's Avatar
ok...
95ejjj
Welding / Fabrication
Apr 22, 2011 10:13 AM
sleepystyle
Apr 1, 2006 09:24 PM
jfboy
17
Jul 20, 2005 05:43 PM
fandango
Mar 23, 2005 02:05 PM
project dc2
Jan 25, 2003 12:24 AM
