CEL problem, and other problems after swap.
Old Jan 23, 2003 | 06:19 PM
Soled Out's Avatar
Default CEL problem, and other problems after swap.
Car: 1993 CX, Motor: jdm b16a II pr3 obd-1 ecu
I finished everything with my swap, start it up, and take it for a spin. When i first hit the throttle, it kinda hestitates/bogs, the goes. Then at about 3k rpms it hits a fuel cut off/ redline. My CEL light in the dash is on which leads to the second problem. I found the connector that needs to be jumped, to get the CEL to flash, i jumped it, but the CEL dont flash, so therefore i have no clue what code its throwing.
Anyone have any ideas why my car bogs, and hits a fuel cutoff? And why my CEL wont flash after i jump the connector?
TIA
Old Jan 23, 2003 | 08:55 PM
Soled Out's Avatar
Default Re: CEL problem, and other problems after swap. (Gray EG)
30,000+ users, yet noone has any ideas?
Old Jan 23, 2003 | 09:44 PM
TEAMGENDAI's Avatar
sounds like a faulty ecu if you tried the jumper and the car does not display a cel. if the car does not rev past 3k you might have to change the ecu. sounds liek a ecu problem. just my opinion. also is your ecu reprogramed?
[Modified by TEAMGENDAI, 6:45 AM 1/24/2003]
swappedcx
Feb 16, 2006 10:38 PM
liquidxEG
Feb 22, 2005 03:46 PM
Pfieff
Aug 31, 2003 05:23 PM
Soled Out
Jan 26, 2003 05:47 AM
Soled Out
Jan 23, 2003 06:59 PM
