Single oil pump bolt causing leak?
Old Jan 23, 2003 | 01:30 PM
Kamin's Avatar
Default Single oil pump bolt causing leak?
Ok about 3 weeks ago i changed my timing belt while i had my motor out of the car (new transmission was comming)
i had the incorrect tensioner (i did not know this at the time.). i thought i could remove 1 of the small bolts from the oil pump and see if i could get the tensioner working (the lower hook was hitting the bolt. i thought it was the problem.)
well long story short everything is back assembeled and running but i have this funky oil leak comming from somwhere (dont know where)
could this single bolt have caused a leak? (yes i replaced the bolt, and i didnt use any loctite or liquid gasket to seal it.)
Old Jan 23, 2003 | 01:37 PM
SuperSH's Avatar
Default Re: Single oil pump bolt causing leak? (Kamin)
Is oil leaking from the crank/timing belt area? If so you may have broken the seal that seals the oil pump to the block just by removing one bolt. Locate the source of the leak first.
Old Jan 23, 2003 | 01:39 PM
Kamin's Avatar
Default Re: Single oil pump bolt causing leak? (SuperSH)
its kinda hard to do that without removing the timingbelt etc.
id rather not do that unless i absolutley have to.
im just wondering if anyone has heard of one bolt causing a leak (only when the car is on, wich also makes me belive its a pump related leak)
if all else fails im gonna remove the bolt and then coat it in liquid gasket and see what happens.
Old Jan 23, 2003 | 04:22 PM
Shawn C's Avatar
In The Garage
yeah, man that one bolt could have done it. i know it sucks, but if i was you i would take out the driver's side mount, and lower the engine down on that side. thatll make it easy to get to, and it should be a 1 day job easy. id just replace the oil pump, since theyre not too expensive, and seal good w/ hondabond. good luck mang
redred1188
Feb 18, 2020 06:20 AM
SC_Yunzer
Jun 14, 2012 05:16 PM
WifesVTEC
Jun 9, 2005 08:58 AM
eg crunkmonster
Feb 3, 2004 08:47 PM
