Drum Replacement
Old Jan 23, 2003 | 11:59 AM
totaled's Avatar
Default Drum Replacement
Im changin the front disk rotors and pads on my 97 civic ex, wondering if the back shoes are needed as well, or are they a much less frequent thing needed?
Old Jan 23, 2003 | 02:29 PM
ryanstev's Avatar
Default Re: Drum Replacement (totaled)
If the last time they were replaced was when you had your front brakes replaced, then they'll still be ok.
Otherwise, you should have a look, I'm not sure what the minimum size should be though.
Old Jan 23, 2003 | 04:22 PM
tominos's Avatar
Default Re: Drum Replacement (ryanstev)
replace the shoes in the rear, every two time you replace the front.
Old Jan 23, 2003 | 06:03 PM
TRENDSETTLER's Avatar
Default Re: Drum Replacement (tominos)
min wear on the back should be 2mm i believe or thats what at tech told me once
shahriar35
Feb 23, 2010 01:19 AM
brockscivic
Aug 26, 2006 12:31 PM
carracr625
Nov 29, 2004 12:58 PM
advanracing62
Nov 1, 2002 02:02 PM
