can someone measure there tial spring?
Old Jan 22, 2003 | 01:20 PM
shortyz's Avatar
Default can someone measure there tial spring?
hey guys. can u measure how big the tial spring it.
like diameter and length.
i assume the .5 bar is just a lower spring rate then the 1.5 and not actually longer?
Old Jan 22, 2003 | 01:52 PM
boostaholic's Avatar
Default Re: can someone measure there tial spring? (shortyz)
I know the diameters are different between different springs, forgot about the length. I've got a couple springs in the shop i can measure for you later.
Old Jan 22, 2003 | 02:32 PM
shortyz's Avatar
Default Re: can someone measure there tial spring? (boostaholic)
thanks. that would help me out alot.
Old Jan 22, 2003 | 10:46 PM
shortyz's Avatar
Old Jan 23, 2003 | 02:20 PM
shortyz's Avatar
anyone?
Old Jan 23, 2003 | 03:35 PM
Here ya go :
Picture is of a Tial 40mm wastegate .45bar spring and .8bar spring (left to right)
.45bar - 1.875" diameter 3.375" length
.8bar - 2.355" diameter 4.100" length
.8bar is noticeably tighter wound than the .45bar
Hope that helps!
Old Jan 23, 2003 | 03:40 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
does anyone know if they have a color chart to determine which is which? im kinda curious myself, i just bought a new spring for my 46mm, and just want to double check that its the correct one, and also because i have several of them here at my place, thanks, Ron
Old Jan 23, 2003 | 03:44 PM
Default Re: can someone measure there tial spring? (SIXTYdashONE)
Ron not sure, i'd like to know too. I just keep my springs in seperate boxes so i don't get them mixed up. The springs don't have any kind of markings on them either and they are all red on the bottom and silver on the top so i can't really see any other way of distinguishing them from each other. Those suckers are tough to change out on the car while on the dyno!
Old Jan 23, 2003 | 04:14 PM
HT's Biggest Loser
Hehe, well in that case, does anyone know what the blue one is? i have a lil blue one for my big 46mm.. maybe someone can double check for me, I got the spring from a very good HT seller, but you can never be so sure, ya know..
Old Jan 23, 2003 | 04:23 PM
PeakBoost's Avatar
B*A*N*N*E*D
tial color chart
color and size pressure for 35mm/40mm/46mm (psi)
small yellow 4.35/3.63/2.90
small red 6.53/5.80/4.35
small green 9.43/7.25/5.80
small blue 11.60/8.70/7.25
large yellow 13.78/10.15/8.70
large red 15.95/11.60/10.15
large green 19.58/21.75/11.60
large blue 21.75/14.50/13.05
combine large and small springs together for desired boost levels.
hope this helps
Old Jan 23, 2003 | 04:44 PM
Default Re: can someone measure there tial spring? (CHEAPTURBOdotCOM)
Kick ***! Thanks cheapturbo, you are the man!
Old Jan 23, 2003 | 05:25 PM
HT's Biggest Loser
thanks dOOd
Old Jan 23, 2003 | 10:11 PM
shortyz's Avatar
kickass!
Old Jan 23, 2003 | 10:19 PM
shortyz's Avatar
uhm i dont see PSI in there..
im confused.
Old Jan 26, 2003 | 11:00 AM
The values after the color are in psi. For example i'm using a large red in my tial 40mm which is .8bar. According to that color chart it's 11.80psi which is right on the money.
saxqtzk
Oct 1, 2006 08:32 PM
JDM turbo DC
Jan 29, 2006 06:20 PM
bubs
May 18, 2005 05:33 AM
B18PoweredCivic
Jun 27, 2004 08:42 AM
DA-MAX
Mar 3, 2004 12:24 PM
